Old 03-11-2016, 03:21 PM   #1
oldlostcory
oldlostcory's Avatar
Drives: 2013 WRB BRZ Limited
Nuts for Front Sway Bar End Links.
I ran into issues when installing my new springs. The sway bar end links were rusted. I'm going to have to cut them. So I ordered some new oem sway bar end links from a dealership. Problem is they didn't come with any nuts. Does anyone know what size I need? Can I pick them up at a local store or will I need to order them online. Thanks
oldlostcory is offline   Reply With Quote
Old 03-11-2016, 04:36 PM   #2
oldlostcory
I'm going to leave this post up just in case anyone is as clueless as I was. The part number for these nuts are - 902370063. They need to be ordered seperately. I got them from this schematic http://parts.subaru.com/a/Subaru__/4...10-200-01.html
Old 03-11-2016, 06:21 PM   #3
strat61caster
strat61caster's Avatar
You could probably find the right size nut at any hardware store just walk into the store with sway bar link in hand and try them out, employees should be helpful, it won't have the flange and I can't remember if it has a locking feature but a touch of mild loctite would guarantee no problems.
ineedyourdiddly
Old 03-12-2016, 06:00 PM   #4
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
Looks like you have the issue solved.
For future reference the size is M12x1.25 it is a flange nut. This typically is not a common size in hardware stores but some may carry it.
Jeff@Racer X Fab is offline   Reply With Quote
The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post:
oldlostcory (03-14-2016)
Old 04-05-2017, 10:42 AM   #5
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
I'm gonna resurrect this thread to offer a bit of advice to anyone looking for these flange nuts.
If you need them on a tight timeline (as in you broke one or are planning to install something in the next day or so) call Subaru dealers for the Subaru OE number (902370063). These nuts are a fit for pretty much every Subaru model, so they're usually in stock at most Subaru dealers. Whereas, on the Toyota side they only fit the FR-S and are a lot harder to locate in stock with the Toyota PN (SU003-00053).
I called 4 Toyota dealers in my area and none of them had them in stock. Called two Subaru dealers and found 7 total between both locations.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following 2 Users Say Thank You to Shark_Bait88 For This Useful Post:
Shinchu (04-05-2017), Tcoat (04-05-2017)
Old 04-05-2017, 11:42 AM   #6
Shinchu
Shinchu's Avatar
Drives: 2016 FR-S Asphault MT
I pulled threads off (over-torque?) on the rear lower arms bolt for the strut.
I got a grade 8 replacement but a factory 10 would be more comforting.
good to know!
TEAM HINGA | Shift-Lock.net | Club4AG
http://www.poweredbymax.net/
Shinchu is offline   Reply With Quote
The Following User Says Thank You to Shinchu For This Useful Post:
Shark_Bait88 (04-05-2017)
Old 06-27-2019, 07:25 PM   #7
AT-JeffT
Drives: 14 BRZ SWP
That Toyota Part # is not the correct number. That nut is very tiny, certainly not an M12. It looks like the correct part # is SU003-02868
AT-JeffT is offline   Reply With Quote
WTB- Front sway bar adjustable links solort Want-To-Buy Requests 1 09-02-2015 10:02 PM
Front Sway bar end links rick s Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-09-2015 11:33 PM
WTB: Whiteline Front sway bar Links. Filipino Royale Brakes, Suspension, Chassis 0 08-06-2014 02:46 AM
22mm Perrin Front Sway Bar and End Links ramiram1984 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-18-2013 12:31 AM
