Old 09-07-2019, 08:11 PM   #1
Daver
P000B
p000b "engine position system performance - bank 2"
72K, No boost or tune, just got cam carrier seals redone. Something they did perhaps? Should I try to change OCV?
Thanks
Daver is offline   Reply With Quote
Old 09-07-2019, 11:29 PM   #2
humfrz
Oh, I'd suggest you take it back to whoever did the work and ask THEM to fix it -
humfrz
Old 09-07-2019, 11:35 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
i thought this was an OT discussion about poop.
nevermind then.
Old 09-07-2019, 11:54 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
Old 09-08-2019, 03:25 PM   #5
Ultramaroon
not playing cards
They used too much glue and it got into/through the ACVS filter. Either that or a little fleck of schmutz broke free and jammed the spool valve in the phasor.
Old 09-09-2019, 11:23 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Thanks
I don't get people's logic sometimes.
Go back to whoever did the carrier seal replacement. It's not a coincidence this issue occurred after the seal redo. I don't know why you'd go STRAIGHT to replacing the OCV.....
Old 09-10-2019, 12:09 AM   #7
Ultramaroon
not playing cards
At least OP did some light reading. There's some logic to the suggestion but it's off the mark.
Old 09-10-2019, 10:49 AM   #8
Daver
I had read part of the Subaru service manual on P000B is to swap OCVs and see if it then throws the code for the other bank. This was before I heard the code could also be created by the glue.
Thanks Man
I wonder if I have any leverage when the dealer claims they had nothing to do with it? (service manager already tried to minimize the possibility a service tech botched something) Does it help to call SOA or anything?
Old 09-10-2019, 03:34 PM   #9
Ultramaroon
not playing cards
Yup. It's possible but unlikely. The OCV isn't actually a valve. It's an actuator more closely related to the arm on a hard drive or a speaker. A voice coil accepts a signal to drive a pin which acts on the spool valve in the middle of the camshaft phasor. It's possible that it could fail slowly by getting weak and it's easy to verify but given your circumstances, a partially plugged oil passage is way more likely.
Thanks Man
I seriously doubt that it will go that far. The correlation is a no-brainer. Don't wait for it to ruin your ECU by permanently throwing it out of whack. That's real.
Old 09-10-2019, 03:49 PM   #10
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The better question is, what harm could it possibly do? Fight and defend yourself, unless you like being walked on. Don't know too much, but be assertive. And above all else, do not let THEM convince YOU that it wasn't their fault.
The difference between defeat and giving up, is that at least with defeat, you had a chance.
Old 09-10-2019, 09:13 PM   #11
Daver
Interesting, kinda like a Phonograph Thanks!
Cheers, Good advice, there's no quit in me, Just want every tool in the drawer should It come to that.
Old 09-19-2019, 04:30 PM   #12
Daver
@Ultramaroon Thanks for the input! Using your verbage I went in there and supirsed the service manager With my knowledge. They swapped the upper OCV and got the code for Bank 2, surmising that the OCV was bad.
They replaced it no charge, and a few hundred miles later I still have no code, I guess I hope they were right, but I have got to think you guys are on the correct track, some smultz came loose and clogged that actuator, possibly that smultz has some friends still bouncing around in there and waiting to wreck something else. At Least I fired off an email to the service manager describing that posibility prior to them replacing the OCV, so if something crops up there is a paper trail, though I fear I might not win that argument... but Fingers crossed no issues. Thanks again guys
Code P000B CTB727 Issues | Warranty | Recalls / TSB 15 10-15-2023 12:19 PM
P000B and P0017 Abaier Issues | Warranty | Recalls / TSB 5 12-24-2018 03:23 PM
Dreaded p000b; Please Help! majixmatrix Issues | Warranty | Recalls / TSB 19 04-27-2018 10:57 AM
Fault Code P000B, before I got to the dealer TURBObro10 Issues | Warranty | Recalls / TSB 4 11-08-2016 04:29 PM
p000b Djratrap Issues | Warranty | Recalls / TSB 8 08-29-2016 02:33 PM
