Old 09-04-2019, 03:57 AM   #1
jbsali
jbsali's Avatar
Drives: 2014 Subaru BRZ (Limited)
Question Optional RCA Harness for Fujitsu Ten Head Unit?
Is there a plug and play harness to add RCA's to install an aftermarket amp? I'm looking for something that I can put behind the headunit.
I'm fully aware you can run a line convertor from the rear speakers and yes this is an option. I even have one. I just want to keep the setup and wiring as clean as possible as I might end up upgrading the headunit in the future.
I did some digging and have found harnesses, but none that include RCA for amp output.
Any help would be greatly appreciated. Thanks in advance,
jbsali is offline   Reply With Quote
Old 09-07-2019, 11:55 PM   #2
greencounty
greencounty's Avatar
The Fuji-Ten units don't have a line level output. The line output converter is your only option. (although there are harnesses and adapters to avoid cutting factory wiring)
Garage:
2013 BRZ Limited 6MT - Galaxy Blue
1994 Ford Probe GT 5MT - Red(some would argue pink)
1969 Mustang Fastback 4MT - Royal Maroon
greencounty is offline   Reply With Quote
2013 BRZ Limited Fujitsu head unit suddenly stopped working. SkvLTD Electronics | Audio | NAV | Infotainment 1 08-05-2018 05:48 PM
2016 BRZ Head Unit Wiring Harness TommyC Electronics | Audio | NAV | Infotainment 84 08-18-2017 12:05 AM
FUJITSU HEAD UNIT SD CARD Bono Electronics | Audio | NAV | Infotainment 6 03-11-2017 10:44 AM
SOLD!! 2014 BRZ OEM Fujitsu Head Unit with GPS Antenna and SD Card BRZedsDeadBaby Audio/Visual, Electronics, Infotainment, NAV 20 04-12-2016 12:15 AM
Doggone FA632US Fujitsu head unit KamikazeChaz BRZ First-Gen (2012+) — General Topics 4 06-09-2014 04:41 PM
