Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Members Classifieds > Audio/Visual, Electronics, Infotainment, NAV
Old 03-26-2016, 01:09 AM   #1
BRZedsDeadBaby
BRZedsDeadBaby's Avatar
Drives: 14 BRZ
SOLD!! 2014 BRZ OEM Fujitsu Head Unit with GPS Antenna and SD Card
SOLD!!
BRZedsDeadBaby is offline
Old 03-26-2016, 11:39 AM   #2
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by BRZedsDeadBaby View Post
2014 BRZ OEM Fujitsu Head Unit with GPS Antenna $300 picked up $320 shipped firm
Is sd card included? Ppl will care about that. If so this is a steal for ppl
lbroskee is offline
The Following User Says Thank You to lbroskee For This Useful Post:
BRZedsDeadBaby (03-26-2016)
Old 03-26-2016, 02:59 PM   #3
BRZedsDeadBaby
Drives: 14 BRZ
Sure is. Thanks for pointing that out.
Old 03-26-2016, 03:02 PM   #4
NahumCC
Drives: 2013 FR-S 10 Series
Anybody swapped these into the FR-S? I'm also curious to where the bracket mounts up for the GPS antenna there.
NahumCC is offline
Old 03-26-2016, 03:12 PM   #5
BRZedsDeadBaby
Drives: 14 BRZ
I've heard that these work in FRS's, but you should confirm by digging around a bit. The bracket mounts to the right of the head unit inside the dash.
Old 03-26-2016, 03:29 PM   #6
lbroskee
lbroskee's Avatar
I did, works great tho my fm signal is weak and just haven't gotten around to fixing it but there is a fix. Ppl have then working 100%
lbroskee is offline
Old 03-28-2016, 03:39 PM   #7
BRZedsDeadBaby
Drives: 14 BRZ
Originally Posted by khantran04 View Post
any install instructions
I want gps I live in garden grove like 15 min from Costa Mesa just want to know I might pick up
Sent from my SM-N910T using Tapatalk
I don't have install instructions, but I installed an aftermarket headunit in my BRZ and it wasn't very difficult at all; just a lot of different wires.
I imagine installing the BRZ OEM unit into your FRS would just be plug and play as the pin connectors look the same.
Old 03-28-2016, 03:46 PM   #8
lbroskee
lbroskee's Avatar
Correct. There is a guide on here somewhere for XM and to fix the 1 missin FM pin
lbroskee is offline
Old 03-31-2016, 03:52 PM   #9
BRZedsDeadBaby
Drives: 14 BRZ
bump
Old 03-31-2016, 04:01 PM   #10
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
It's won't readily work in an FR-S without of course the antenna which is already there or go aftermarket magnetic to stick on the bar that runs behind the head unit. Also the Fm signal will be weak because the FR-S HU sends power to the car's antenna booster amplifier via the separate single-conductor wire on the AM/FM antenna connector. The BRZ HU sends the 12V power antenna signal out via pin #8 on the 10-pin power/speaker harness. You'll need to rig up an adapter harness (or at least, add a jumper wire from the vacant slot on your car's 10-pin plug to the factory pin/wire on your car's AM/FM antenna plug.
Theres a bar behind the head unit you can remove the antenna from the the bracket and use double sided tape or velcro to attach it there, or alternatively you can get an aftermarket antenna which tends to work just as good if not better but is also magnetic and will turn that bar into an extension of the antenna and it just sticks onto there. and works perfectly.
I only know this stuff because I really wanted navigation and settled on buying an entune module and updating my current head unit without the headache of repinning or rewiring things and get pandora on my head unit now, a decent navigation system and a bunch other features like weather and traffic.
FRSBRZGT86FAN is offline
Old 03-31-2016, 06:49 PM   #11
lbroskee
lbroskee's Avatar
Do u know which min I need to tap into? Lik back of empty radio pin tapped into which wire? I can't find the post that said it. Would the acc wire do it (same 1 used for my backup camera)?
lbroskee is offline
Old 04-03-2016, 11:00 AM   #12
BRZedsDeadBaby
Drives: 14 BRZ
Bump
Old 04-03-2016, 04:33 PM   #13
Mvhs09
Drives: Brz
I have a hyper blue brz...how hard is it to throw this in there? Do I have to swap out some of the center console stuff or is it a direct fit?
Mvhs09 is offline
The Following User Says Thank You to Mvhs09 For This Useful Post:
Jordan Silveira (04-03-2016)
Old 04-03-2016, 05:47 PM   #14
BRZedsDeadBaby
Drives: 14 BRZ
The hyper blue is a 2016 model right? If that's the case, then the center dash piece needs to be swapped with a 2015 or earlier model. Do you not have a head unit in your hyper blue?
The Following User Says Thank You to BRZedsDeadBaby For This Useful Post:
FUJITSU HEAD UNIT SD CARD Bono Electronics | Audio | NAV | Infotainment 6 03-11-2017 10:44 AM
FS OEM BRZ Head Unit Navigation with maps and GPS antenna seant2h Audio/Visual, Electronics, Infotainment, NAV 5 05-18-2015 03:54 PM
'14 BRZ Nav Head Unit w/GPS antenna Raven23 Audio/Visual, Electronics, Infotainment, NAV 3 10-26-2014 07:28 PM
SOLD: BRZ Nav Head Unit w/GPS antenna $290 shipped. blewclouds Audio/Visual, Electronics, Infotainment, NAV 20 07-16-2014 05:26 PM
Doggone FA632US Fujitsu head unit KamikazeChaz BRZ First-Gen (2012+) — General Topics 4 06-09-2014 04:41 PM
