Drives: 2014 BRZ LIMITED
I've seen other people with a similar problem posting on some forums, but no definitive solution was given... so let me try again:
I bought a used BRZ 2014 Ltd, and had it shipped outside the US (to El Salvador). The HU (Fujitsu FA632US) did not include the SD card that holds the nav maps. I did not consider this an issue since I'm not planning to use the NAV feature anyways (Subaru has no maps available for this region). But to my surprise, the HU will not even load up without the SD card (The battery was disconnected during shipping). All I get is a black screen and this: “Program loading necessary. Please insert SD card”. I’ve been to the local Subaru dealer to no avail; they are not used to see this type of HU. SoA tech support said I need to purchase a new card from a US Subaru dealer… but the idea of buying a $200-$300 SD card with maps I will never use seems a bit dumb. Has anyone figured out a way to make an image copy of the SD card? I’ve read that the card is copy protected. Other people have tried to copy the files to a blank SD card, but the HU would not read the maps from this copy. But I’m thinking that maybe if someone is willing to send me the files, it wouldn’t hurt to try and see if the HU is able to read the loading software from the copy. There must be a way to fool the HU, any ideas? ![]() Now this is more of a rant... , but I wonder why would Subaru/Fujitsu design the HU in such a way that it will not work properly without the card. It makes sense to have a removable device to hold the map info (so it can be updated)... but why also include in it the software the HU needs to start up???NOTE: The blue card on the pic below is just a blank |
Drives: Subaru BRZ '13 WRB
I could send you image file, but pretty sure it will not work
I researched quite a lot about this topic. Files in card are encrypted to SD card CID number. Thus simply rewriting files to other SD card will not work - original card is required. But I have backup of SD card image on other computer, let me know if you wish me to send it (4gb file).
#3 | |
Drives: Lightning Red 2015 BRZ;F150 Limited
I would think you should be able to find one from a wrecked car. This is listed on Craigslist in the Seattle area. Maybe they could ship?
http://seattle.craigslist.org/tac/pts/4935335010.html |
Update: I tried using the copied card from an image file.... It did not work, but the HU did recognize a card being inserted and appeared to start loading, but then nothing happened (if I insert a blank one I immediately get a message saying "check the SD card").
I will end up getting one from the US... but it will probably take some time to get here. Meanwhile, I wanted to try something else... the image file I used was I believe from a 2013 BRZ. Anyone with a 2014 BRZ willing to share the image copy of the card (PN 86283CA630) with me? (the Subaru PN of the cards are different depending on the year). |
Drives: 10 Series #974 6m/t
if no luck then most likely you will have to change the HU.
Drives: 2013 Scion FRS
I have the same problem.
Sent from my LG-K550 using Tapatalk |
| Tags |
| audio, navigation, sdcard |
| Anybody know ... what head unit this is? | chaoskaze | Electronics | Audio | NAV | Infotainment | 3 | 12-21-2014 06:44 PM |
| Doggone FA632US Fujitsu head unit | KamikazeChaz | BRZ First-Gen (2012+) — General Topics | 4 | 06-09-2014 04:41 PM |
| FR-S Head Unit in BRZ? | gatsbysghost | Electronics | Audio | NAV | Infotainment | 6 | 04-22-2014 07:52 PM |
| BRZ Nav Head Unit | Sojhinn | Audio/Visual, Electronics, Infotainment, NAV | 16 | 11-03-2013 06:02 PM |
| head unit in GTA | excited86 | Electronics | Audio | NAV | Infotainment | 1 | 06-18-2012 07:42 PM |
