Old 08-30-2019, 09:18 AM   #1
Alfrz91
Drives: 13 Scion Frs
Manual engine into an Auto?
I've found a seemingly good deal on a manual engine, would it be relatively simple to take whatever I need off of my blown auto and transplant it into the manual engine to get it going? Or do I need to find an automatic engine?
Alfrz91 is offline   Reply With Quote
Old 08-30-2019, 09:42 AM   #2
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
They are interchangeable. There's a few things you'll need to remove from your auto engine to transplant it over.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
The Following User Says Thank You to Soloside For This Useful Post:
Alfrz91 (08-30-2019)
Old 08-30-2019, 09:51 AM   #3
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
2017+ motor? If so that's a good look. I love that red manifold.
SUB-FT86 is offline   Reply With Quote
Old 08-30-2019, 09:54 AM   #4
Alfrz91
Unfortunately not haha. It would be a 13 manual engine into a 13 automatic. (a recall victim)
Old 08-30-2019, 09:56 AM   #5
Alfrz91
Thanks, someone said it would be costly but i think they maybe didn't understand the question. This would have to far and away be more cost effective than buying a short/long block, right? Not just on parts, but labor mostly.
Old 08-30-2019, 10:45 AM   #6
Soloside
would be like an extra hour of labor. I put a manual motor into my auto one.
2014 Subaru BRZ
Old 08-30-2019, 01:02 PM   #7
Alfrz91
Perfect. Any idea what installation all ran you?
Old 08-30-2019, 05:20 PM   #8
ls1ac
ls1ac's Avatar
Been asked many times before. Short answer is do not do it. Middle answer is placement and fit is easy, electronics are a bitch. Long answer and all that needs to be replaced and rewired has been answered before.
Old 09-17-2019, 08:41 AM   #9
Alfrz91
I couldn't find it anywhere that it's covered or been asked many times before. I've seen the opposite, auto into a manual, but thats not what we were talking about here. Not sure why the short answer would be to not do it if the placement and fit is easy, and the motor's are already out?
Old 09-17-2019, 09:28 AM   #10
Are you guys sure you understand the question? My reading of it is its not about replacing the transmission, its about taking an engine that was in a car with an MT and putting it in a car with an AT. It's an engine swap not a transmission swap.
Cole (10-23-2019), kmbkk (10-23-2019), soundman98 (10-23-2019)
Old 10-23-2019, 07:22 AM   #11
Nawar
Drives: 2016 Red GT86
I have the same Situation here, i want to Transfer an engine from a MANUAL car to my Automatic Car, how hard can it be when the engines are exactly the same, with a difference of Flywheel/Torque Converter
Nawar is offline   Reply With Quote
Old 10-23-2019, 10:27 AM   #12
The first response here is right. You just have to swap over some parts as you said. There is also a brake booster pump you need to change but no big deal.
Swapping a 17+ engine is where it gets complicated.
Lantanafrs2 (10-23-2019), soundman98 (10-23-2019), Tristor (10-23-2019)
Old 01-19-2021, 01:50 PM   #13
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Wanted to cross post since this is one of the top threads, you can find good info here instead
https://www.ft86club.com/forums/show...59#post3400759
I added some posts recently about MT engine into an AT as most people seem to be opposite so the hiccups are a little different and not as easy to solve on the spot.
Differences between auto and manual engine redlined600 Engine, Exhaust, Transmission 38 06-21-2023 11:35 PM
Any issues installing FA20 Auto Engine into Manual Car jamison884 Engine, Exhaust, Transmission 1 10-16-2017 09:21 AM
BRZ Manual Or Auto? JT2Swag Scion FR-S / Toyota 86 GT86 General Forum 45 06-29-2016 03:05 PM
Engine from Auto car into a manual car? John Rambo Engine, Exhaust, Transmission 8 11-26-2015 04:54 PM
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado huma BRZ First-Gen (2012+) — General Topics 15 06-14-2012 11:33 AM
