Old 11-24-2015, 08:41 PM   #1
John Rambo
John Rambo's Avatar
Drives: Turbo BRZ Limited 6MT
Engine from Auto car into a manual car?
So, I'm swapping my blown motor with a junkyard motor, and I came across one on ebay that appears to be taken from an automatic.
The shop I've taken my car to for the swap is not sure if everything is the same, particularly some of the electronics.
Does anyone know if I'd run into issues using the engine pulled from an auto car? J
Thanks in advance.
John Rambo is offline   Reply With Quote
Old 11-24-2015, 09:23 PM   #2
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
I can't see why not, but then again, modern tech has advanced so far much that you probably could and I might be missing something here.
Old 11-24-2015, 09:54 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
You'll have old original ecu from manual, right? And it's firmware version will be fitting to engine version? (heard there were some changes in MY2015 engine in cams and alike, no? .. i guess firmware in ecu should better match those changes)
Old 11-25-2015, 08:34 AM   #4
celek
Resident Gear Head
celek's Avatar
Swap flywheel on, the electrical wiring harness from the MT car has to be used as you do not have the shift solenoids anyhow. Other than that mechanically I am pretty sure its a direct change over. No extra sensors that I am aware of.
Small things like below show an AT oil pipe which is capped on a MT with a bolt.
http://parts.subaru.com/a/Subaru_201...10-006-01.html
celek is offline   Reply With Quote
Old 11-25-2015, 10:23 AM   #5
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
the upper oil pan on the auto has a small nipple for a coolant line, the manual has it blocked. other than that its all pretty straight forward when they are side by side.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 11-25-2015, 10:45 AM   #6
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
You will have to take off the vacuum pump on the passenger cylinder head, too, and replace it with the block off plate that exists on the manual.
FrX is offline   Reply With Quote
Old 11-25-2015, 11:36 AM   #7
wparsons
wparsons's Avatar
If you have the blown motor, and the "fresh" auto motor you have everything needed to put the new one in the car. Nothing internal is different, just some external parts (as mentioned already).
flickr
Old 11-26-2015, 02:37 PM   #8
John Rambo
John Rambo's Avatar
Okay. It still seems like slightly less labor to buy a motor from a manual so I think I'm going to do that.
Thanks guys
Old 11-26-2015, 04:54 PM   #9
wparsons
wparsons's Avatar
^^ Compare the labour rate (or how much you value your own time) to the price difference. I'd imagine an hour or two to swap stuff over.
flickr
Manual vs. Auto? Cattronic Scion FR-S / Toyota 86 GT86 General Forum 55 02-11-2014 12:37 PM
Auto to manual ric342 Scion FR-S / Toyota 86 GT86 General Forum 135 04-10-2013 11:43 PM
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado huma BRZ First-Gen (2012+) — General Topics 15 06-14-2012 11:33 AM
Manual or Auto? StevenDavisPhoto Engine, Exhaust, Transmission 23 03-30-2012 05:58 AM
