Old 08-26-2019, 02:41 PM   #1
Sev995
Drives: Black 2013 frs
Limp Mode no Code
Hey guys my 2013 FRS threw a warning light for a few seconds because my coil packs were acting up. However, ever since it flashed, my car has been revving in limp mode with a what feels like 40% power loss at full throttle. Normally whenever the light goes off, I can just reset the thrown code in my oft but nothing is there to turn off. Any thoughts? The coil packs have been replaced recently with around 2k mi on them. I have looked through alot of forums on here but I haven't been able to find the correct ones. Help!!!
2013 FRS, Tomei EQ Header, Perrin performance air filter, Stage 2+ OFT tune, W/ aftermarket exterior.
Sev995 is offline   Reply With Quote
Old 08-27-2019, 09:30 AM   #2
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
What makes you think the coil packs were acting up? How many miles on the car? Any other recent mods to the car? There have been limp mode issues in the past due to certain wiring that has come loose. Also, what lights show up on the dash?
Dzmitry is offline   Reply With Quote
Old 08-27-2019, 11:34 AM   #3
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
The car might have stored the code even though the CEL is no longer on. I'd recommend plugging in an OBDII scanner and see if it'll give you any codes. Flashing CEL usually indicates misfire, but it would be nice to isolate it to a cylinder if possible.
MCTeeJ is offline   Reply With Quote
Old 08-27-2019, 09:44 PM   #4
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Correct me if I'm out to lunch, but doesn't a battery disconnect flush most things (other than the ROM).
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 08-29-2019, 04:02 PM   #5
fika84
fika84's Avatar
Also remember that OFT doesn't show codes for all ECU's...
fika84 is offline   Reply With Quote
OFT Code U0122.. Limp mode.. Help cameronjones239 Software Tuning 16 05-19-2021 12:25 AM
Limp mode GTBOY Issues | Warranty | Recalls / TSB 4 06-07-2018 12:58 PM
Valet mode / limp mode? radroach Software Tuning 1 09-18-2017 11:34 AM
How to limp mode.. vichiball Software Tuning 5 07-12-2016 01:18 PM
Car in Limp mode... No CEL Sportsguy83 Issues | Warranty | Recalls / TSB 60 08-20-2014 03:35 AM
