Old 08-22-2019, 05:44 PM   #1
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Front lip question
I'd like to get a front lip\splitter however the car is lowered 3\4" and the underneath portion of the front bumper already scrapes sometimes. is there a lip or front splitter that the actual lip sits a bit above the bottom of the bumper? Looking at them on websites it can be hard to tell.
Old 08-22-2019, 05:56 PM   #2
Joyride86
Joyride86's Avatar
Drives: 15 FR-S Firestorm MT
Since all of the lips/ splitters are mounted below the front bumper, I think you're SOL. However, the scrapes are on the bottom so they won't really be seen unless someone lays on the ground to look at it.
Diode Dynamics Tail as Turn, LEDs, HIDs | Yospeed Custom Plaque and Frame | Suntek Carbon Tint | Spyder Smoked Side Markers | GrimmSpeed License Plate Relocator and Hood Struts | Five:AD Spoiler | JDM Armrest | Beat-Sonic Backup Cam | Moddiction Anvil 2 | Invidia N2 |
Joyride86 is offline   Reply With Quote
The Following User Says Thank You to Joyride86 For This Useful Post:
TommyW (08-22-2019)
Old 08-22-2019, 06:15 PM   #3
TommyW
TommyW's Avatar
correct. I’m just worried about it ending up being too much lower and being torn off but I guess this is one of those things that you just have to take a chance
Old 08-22-2019, 06:45 PM   #4
spike021
spike021's Avatar
I'd just get a cheaper one. Most are plastic anyway so just plan on maybe having to replace it after a year or two. But also learn to angle as much as possible/whenever you can.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
TommyW (08-22-2019)
Old 08-22-2019, 06:55 PM   #5
TommyW
TommyW's Avatar
Yeah that’s what I’m thinking
Old 08-22-2019, 07:49 PM   #6
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
JDM TRD lip doesn't go that much lower than OE, and it is secured on top and bottom. Never had a problem with it, and I regularly track the car (and occasionally run off the track)
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
TommyW (08-22-2019)
Old 08-22-2019, 08:12 PM   #7
TommyW
TommyW's Avatar
Awesome. I'll check it out
Old 08-22-2019, 09:13 PM   #8
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Yeah I plan on getting a super cheap one. Unless I had a bunch of money, I wouldn’t get the carbon fiber ones. From a distance, no one can really tell. The plastic ones still look good and do the job. Just make sure you mount it well and you should be fine. I feel like unless it wasn’t mounted well, it’s hard for it to just fly/scrape off. If it does, a good $200 or so and you’re good, but I doubt that would happen. STI one is totally not worth $500. You going for one with or without splitter rods?
Will BRZ is offline   Reply With Quote
The Following User Says Thank You to Will BRZ For This Useful Post:
TommyW (08-22-2019)
Old 08-22-2019, 11:28 PM   #9
Grey86
Grey86's Avatar
Drives: Tornato grey 86
This I've been running a front lip for almost a year now and im lowed by a inch, you'll have to learn to angle the car it'll take time. Also double sided tape, if you have a curb drive way like me you'll hit the one spot every time and eventually pull the lip screws. But definitely get a cheaper lip or a lip that you can possibly fix up with a bit of DIY.
Grey86 is offline   Reply With Quote
The Following User Says Thank You to Grey86 For This Useful Post:
TommyW (08-23-2019)
Old 08-23-2019, 11:00 AM   #10
TommyW
TommyW's Avatar
Not sure. The smaller ones don't need one however the bigger ones have at least SOME actual downforce which is what I'm after for tracks like Willow Springs.
Front end instability question gravitylover Suspension | Chassis | Brakes -- Sponsored by 949 Racing 34 05-20-2019 03:43 PM
Front-Pipe Question for FRS FewTooManyBeers Engine, Exhaust, Transmission 12 02-15-2019 10:22 PM
Front LCA question caffeinejunky Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 04-30-2014 08:54 PM
Front lip question... brz_guy Cosmetic Modification (Interior/Exterior/Lighting) 13 05-17-2013 01:51 PM
Question About Front Fenders on FRS c0rbin Scion FR-S / Toyota 86 GT86 General Forum 18 05-28-2012 02:40 PM
