Drives: 2015 Scion FR-S
Hello,
Got a question regarding Front-Pipes. From my understanding there are 3 options available for the FRS/BRZ/86. 1. Test-Pipe 2. Front-Pipe with High Flow Cat (HFC) 3. Front-Pipe with Resonator I understand Test-Pipe option is essentially straight pipe. And for most part I understand Front-Pipe w/ High Flow Cat which in it's application should be less restrictive then OEM Cat, but not be as Loud (in Theory) as the Test-Pipe. Since you can make it stupidly loud with some aftermarket UEL's. What I don't understand is Option #3, that is Front-Pipe with Resonator. A Resonator can't act as a Cat, but it's only function is to Cancel out some sound waves which are deemed annoying, aka Drone. If anyone is running Front-Pipe w/ Resonator how does it compare to the Test-Pipe or Front-Pipe w/ HFC. I wan't to slowly start assembling my Exhaust piece by piece this Summer for my 2015 FRS 6AT. And trying to figure out the best route. |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Test pipe = straight pipe. Loudest.
Front pipe with high flow cat = still has cat but a tad louder than stock. Front pipe with resonator = front pipe with no cat but with a muffler basically to lower sound. Louder than front pipe with hfc. |
#3 | |
Drives: UK GT86
You are going to be talking minimal performance differences between all 3 options, so really it's a case of which one suits your needs best. Most of the HFCs that are available will not pass emissions testing here in the UK, so they aren't as good as the OEM cat by a fair bit.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Ultramaroon (02-15-2019) |
Rust bucket enthusiast
I have gotten a dyno tune with stock exhaust with a catless frontpipe vs stock, no WHP gain, stinks, is way loud, I was so happy to switch back. I had a resonated catless front pipe. Really not worth it, I also run catless UEL headers and those add enough volume.
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Tcoat (02-11-2019) |
#6 | |
However that raises question about further improvements that may be needed, like Brakes, Cooling, ect. Nor do I know how the stock FA20 block will handle, I'm not mistaken the stock engine should be good for 340-360 HP. |
Drives: 2017 manual BRZ
I have a full exhaust. Tomei UEL/OP invidia FP and invidia r400. I've been running invidia's test pipe for 2 years. With the setup it sounds really good but always like you're going 100%. There is no in-between. Just accelerating from a light at normal speed sounds like you're trying to race everyone. It also had a bit of rasp at around 3500 when actually accelerating hard.
Just a few days ago I switched over to the resonated Invidia FP. It's seriously night and day. The resonator is straight through and small but extremely effective. Now I don't sound like an idiot at every stop light and have to completely relearn how the car sounds since I shift by sound. What little rasp there was is now gone. Under 4500 it's perfectly tame and smooth. Above 4500 it sounds the same as before just more refined and slightly quieter. Don't have any sound clips but may as well tack on the 2 pipes side by side. ![]() Sent from my Pixel 2 XL using Tapatalk |
#8 | |
#9 | |
#10 | |
#11 | |
Kind of considered BERK Technologies Duel-Tip Muffler Delete + BERK High Flow Cat Front-Pipe mixed with either Borla EL or Tomei EL Headers. The only part I was missing is Mid-pipe and Over-pipe. |
#12 | |
#13 | |
Drives: 2015 Scion FR-S || Raven Black
UEL will fill in more torque in the middle, EL are technically more efficient and will add peak HP. It really comes down to where you want your torque added. Sent from my Pixel 2 using Tapatalk |
| Tags |
| exhaust, front pipe, frs |
| Front Pipe Question | OMGArisman | Engine, Exhaust, Transmission | 5 | 01-23-2016 03:31 AM |
| HKS resonated Front Pipe Question | ray7792 | Engine, Exhaust, Transmission | 10 | 07-05-2015 02:19 AM |
| Front Pipe question | BlackyRose | Engine, Exhaust, Transmission | 3 | 08-04-2014 02:29 PM |
| Tomei Front Pipe question | omgwtfbbqsauce | Engine, Exhaust, Transmission | 1 | 05-07-2014 11:45 PM |
| Agency Power over-pipe/front pipe combo question... | seven | Engine, Exhaust, Transmission | 11 | 01-13-2013 12:14 PM |
