Southern California SoCal
Old 06-14-2018, 01:28 PM   #1
derrickgoes
Drives: 2015 White FR-S
Anyone local with a tech stream that could help? Steering angle sensor issue
Hi guys, I’ve got my abs and slip lights on after a new steering wheel install. I can’t tell if what I need is a calibration via tech stream or a new steering angle sensor completely. I was about to order the part but it is pretty expensive, and I read sometimes it’s a recalibration that might actually be the fix.
Does anyone have a techstream local that would be willing to help me do a recalibration on it? Hoping to give this a shot before ordering more parts. Thanks!
derrickgoes is offline   Reply With Quote
Old 06-18-2018, 07:54 PM   #2
haloterence
haloterence's Avatar
Drives: 2013 whiteout fr-s
I had the same problem a while back. Have you readjusted your clockspring to the center? I did mine with the techstream program I ordered on ebay. It worked for my 13 FR-S. But I'm not sure if it'll work on newer models. We can give it a shot if you're willing to come by. I'm located in Bellflower.
haloterence is offline   Reply With Quote
Old 06-19-2018, 12:05 AM   #3
derrickgoes
Haloterence thanks! I’ve ordered a steering angle sensor I’m going to try to go ahead and replace. But if that fails I think I will take you up on that offer and come out to bellflower. I’ll keep you posted, thanks again!
C1231 - Steering Angle Sensor STS-V Issues | Warranty | Recalls / TSB 6 01-13-2023 10:13 AM
Steering angle sensor reset Brzxton Electronics | Audio | NAV | Infotainment 3 08-16-2019 02:40 PM
Which shop can zero the steering angle sensor and yaw sensors after alignment? krayzie CANADA 5 09-09-2015 07:28 PM
Tech stream in Jacksonville Area kmbkk Southeast 1 07-16-2014 07:48 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 07:39 PM
