Old 08-13-2019, 10:42 PM   #1
GrabTheWheel
Drives: 16' BRZ
Varis version 2 hood with naca duct?
I'm curious if this hood will have a problem with the fitment because of the naca duct if I'm running an aftermarket strut bar? Should I go with version 1 without the naca duct?
GrabTheWheel is offline   Reply With Quote
Old 09-17-2019, 09:39 PM   #2
lextrueno
lextrueno's Avatar
Drives: 2013 Firestorm Frs
From what I have noticed, the NACA duct isn't intrusive into the engine bay. You may have issues routing a vent tube but most NACA ducts do not go low enough to cause issues with a strut bar. I wouldn't worry about it.
What strut bar do you have?
lextrueno is offline   Reply With Quote
Old 09-18-2019, 10:45 AM   #3
GrabTheWheel
Drives: 16' BRZ
Thanks, I’ve confirmed fitment won’t be a problem with strut bar, more worried about the hood ever actually making it here from Japan.
The Following User Says Thank You to GrabTheWheel For This Useful Post:
lextrueno (09-18-2019)
Old 09-18-2019, 12:00 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Why would you want to bring air in from the top of your hood? There is plenty coming through the grill.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Icecreamtruk (09-18-2019)
Old 09-18-2019, 06:00 PM   #5
lextrueno
lextrueno's Avatar
Having the vents like the ones on the varis kit, creates a nice bit of flow from the front of the car going up through the hood. This allows for better cooling and ventilation. The problem that happens is that you create a vacuum which creates a pressurized zone behind the engine. Similar to a fireplace sucking the air from other rooms.
he NACA duct itself was used for aerospace to provide a constant flow of air with no pulsation. It allow smaller amounts of positive pressure airflow to flow from the back of the engine across the coil packs and towards the front of the engine where it meets with the negative pressure area from the large front vents. The cross flow from the back to front of the engine helps cool the heat soak that typically saturates the coil packs.
Old 09-18-2019, 06:03 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Didn't realize this hood was vented too, sounded like it just had naca ducts
MPH Carbon Fiber hood with reverse scoop and NACA ducts! xkalelx Cosmetic Modification (Interior/Exterior/Lighting) 85 05-07-2021 10:15 PM
Custom Hood vs Hood Duct Launcher Cosmetic Modification (Interior/Exterior/Lighting) 55 01-23-2018 10:24 PM
wtb varis style vis hood bjun Want-To-Buy Requests 3 12-16-2015 05:42 PM
Hood Venting, NACA Ducts Lunatic Scion FR-S / Toyota 86 GT86 General Forum 70 02-08-2015 11:10 AM
