Drives: FR-S Turbo
Driveshaft/pinion flange bolt specs?
Would anyone possibly have thread and bolt length specs for the bolts that fasten the driveshaft flange to the pinion flange?
I need to pick up new (longer) hardware as the flange on the end of my DSS aluminum driveshaft is a lot thicker than the stock piece so the bolts are a bit short. Unfortunately, my car is parked (a few hours away) at the track and the hardware supplier is here in town ![]() Thanks in advance for the help. Fingers crossed someone has their out! |
Drives: FR-S Turbo
Found the answer in this thread for anyone else in the same situation:
http://www.ft86club.com/forums/showthread.php?t=110710 It didn't come up in the search here, but I found it through an outside search engine
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
You don't need the washers. Just threadlock and tighten to spec.
| Aluminum Driveshaft Bolt Issues | RJasonKlein | Engine, Exhaust, Transmission | 12 | 02-21-2020 09:31 PM |
| TRD Member Brace Set, Looking for flange bolt part numbers | wulfstan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 42 | 04-03-2017 10:52 AM |
| OEM Rear LCA Bolt Specs | Philly758 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 10-29-2014 08:34 AM |
| Header Flange Specs? | boredom.is.me | Engine, Exhaust, Transmission | 18 | 11-11-2013 04:28 PM |
| Borla UEL flange, more in common with a pretzel then a flange. | Adeets | Engine, Exhaust, Transmission | 13 | 04-12-2013 05:38 PM |
