Old 08-08-2019, 04:12 PM   #1
arnie0000
Drives: Scion FRS
FRS Side Marker Wiring
Hi All,
I am in a bit of trouble here.My passenger's side marker stopped working. I checked the bulb, which is good. The fuse is good as well because the driver's side marker is working. I also have a broken pigtail connection. At this point, my prime suspect is faulty wiring. Does anyone know or a diagram of where that side marker wire comes from? I wanted to start checking the voltage along the wire and see where the fault is. Also, just to confirm, the voltage I should get at the pins should be 12 V, correct?
arnie0000 is offline   Reply With Quote
Old 08-08-2019, 07:59 PM   #2
norcalpb
norcalpb's Avatar
Originally Posted by arnie0000 View Post
Hi All,
Try replacing the harness itself to see if that works:
https://www.subarupartwholesale.com/...SABEgLWNvD_BwE
Old 08-13-2019, 02:42 PM   #3
arnie0000
Drives: Scion FRS
Thanks for your suggestion. I think the wires are shorted somewhere because now I have blown the fuse.
sidemarkers, wiring, wiring diagram
Rest in peace driver side side marker TheRealBFKR Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 01-13-2019 05:05 PM
Wiring BRZ blinker to IJDMTOY side marker? TilesMeague Cosmetic Modification (Interior/Exterior/Lighting) 14 05-09-2018 08:59 PM
WTB: Passenger Side Clear Side Marker Sheepdog Want-To-Buy Requests 0 08-03-2015 08:56 PM
How to Access Side Marker Wiring for Fog Lights? Ammunition Cosmetic Modification (Interior/Exterior/Lighting) 5 01-20-2015 01:51 AM
Side Marker wiring connector IAMTHEWG Cosmetic Modification (Interior/Exterior/Lighting) 0 03-08-2014 07:08 PM
