Old 11-03-2014, 08:16 PM   #1
Ammunition
Ammunition's Avatar
Drives: 2014 Scion FR-S
How to Access Side Marker Wiring for Fog Lights?
Does anyone know how to access the side marker wiring from the engine bay?
I'd like to wire my Diode Dynamics fog light kit to turn on whenever the side markers are on, instead of having them wired to the headlights, but I'm not sure how to identify the wiring to it from the engine bay.
I'd prefer to do this without removing the side markers as my clear ones were a huge PITA to install, and getting them to sit correctly.
Has anyone done this that can offer some insight, or is there a DIY that I'm missing?
Ammunition is offline   Reply With Quote
Old 11-04-2014, 01:37 AM   #2
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Well I tapped into the passenger side marker with my kit. What I did was turned the wheel counter clockwise so I would be able to have access to the fender lining. If you look closely there should be a plastic tab holding the fender lining to the fender. It should be right next to the side marker. Pop the clips out and pull the lining downward to expose the wiring of the side marker. Iirc the white wire is POS, and the black is NEG. Just tap the harness supplied by Diode Dynamics to those wires and you should be set. Hope it helps you and good luck.
Old 01-19-2015, 10:12 AM   #3
torranosaurus
Drives: 2014 FR-S
You wouldn't need a relay if you did this?
Just the fogs wired to each other and then the negative and positive to the marker light wires?
torranosaurus is offline   Reply With Quote
Old 01-19-2015, 10:57 AM   #4
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Side marker should only be used for signal to the relay and fogs should be tapped to battery due to current draw. Unless you want to blow marker light fuses, which includes rear tails. It's all running on a single 10a fuse.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 01-19-2015, 12:57 PM   #5
torranosaurus
Drives: 2014 FR-S
I have seen fogs tapped into the low beam wires as well. That would seem pretty simple if it would work.
Old 01-20-2015, 01:51 AM   #6
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
connect them to the factory [IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Wiring BRZ blinker to IJDMTOY side marker? TilesMeague Cosmetic Modification (Interior/Exterior/Lighting) 14 05-09-2018 08:59 PM
Side Marker wiring connector IAMTHEWG Cosmetic Modification (Interior/Exterior/Lighting) 0 03-08-2014 07:08 PM
Side marker lights gap subiestyle Cosmetic Modification (Interior/Exterior/Lighting) 1 03-06-2014 01:42 AM
FS: JDM clear side marker lights ILL_86 Audio/Visual, Electronics, Infotainment, NAV 3 01-02-2014 05:19 PM
unplugging side marker lights BRZPDX BRZ First-Gen (2012+) — General Topics 2 03-26-2013 11:05 PM
