Old 08-06-2019, 02:02 AM   #1
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Brake pad release: what does this mean?
I have seen a couple of references (hello @CSG Mike !) to brake pad release. That is, the way the brake pad behaves when coming off the brakes.
I'm just a noob track day driver. I release the brakes, slowly or quickly, my car behaves accordingly.
Could someone explain how this characteristics translates to car behavior?
Ta.
Old 08-06-2019, 02:23 AM   #2
Ta.
If you have a pad with great release characteristics, it lets you more precisely modulate trail braking, letting you smoothly shift the load from forward to lateral, allowing you more control on corner entry, as well as superior corner entry speed, and earlier weight shift for better balance.
This requires a pad that has great temperature stability; most of the cheaper race pads get you the higher maximum operating temperatures novices look for after fading their stock or non-track-worthy pads, but that is typically all you get.
You don't find this type of release characteristic until you're at something like a RB340, C1, or H2x grade of pad. Professional motorsports don't use these pads "because they're expensive". They use them because they give the drivers superior confidence and control, which leads to better results. Likewise, this grade of pad is universally more intuitive, allowing beginners more opportunity to learn modulation both on application and release. These pads just also all happen to have better life and thermal tolerance as a byproduct of their formulations.
The Following 6 Users Say Thank You to CSG Mike For This Useful Post:
Captain Snooze (08-06-2019), Icecreamtruk (08-06-2019), Iceman (08-12-2019), ls1ac (08-06-2019), new2subaru (08-06-2019), soundman98 (08-06-2019)
Old 08-06-2019, 06:33 AM   #3
Captain Snooze
Drives: Red Herring
If you have a pad with great release characteristics....
Thank you for the explanation.
Where abouts do you place Carbotech's XP range?
Old 08-06-2019, 02:05 PM   #4
longer pedal travel due to the formulation and press tonnage. Great for beginners who've never used any sort of race type pad before, but too long of a pedal for my preference.
Friction varies with temperature, so brake pedal pressure and modulation/release range changes with the temperature of the pad. Bias also changes with pad temperature differential front/rear.
DIY: Rear Brake Light Removal for Air Release, Diffuser Mod neilvosko DIY (Do-It-Yourself) Guides 2 11-27-2017 06:45 PM
Brake pedal release noise FR-YES Issues | Warranty | Recalls / TSB 4 10-19-2014 04:39 AM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
New Product Release: StopTech Big Brake Kits for Scion FR-S and Subaru BRZ !!! PRO Import Tuners Brakes, Suspension, Chassis 16 08-24-2012 07:59 PM
