Old 11-27-2017, 05:39 PM   #1
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
DIY: Rear Brake Light Removal for Air Release, Diffuser Mod
my goal was to remove the Rear Reverse/Brake Light module in the bottom rear diffuser to let the air out of the "rear bumper parachute" given i replaced the OEM muffler with a dual muffler set, but I did see any info on how. so i climbed under the car and took some pictures for reference.
you will need a small 8 mm socket, (space is too small for a wrench)
two screws on top middle of module
and a medium/standard flat head screw driver, to unclip 2 push pins on each end
then there is compression fitting in the center bottom.
then used 5 small zipties to secure the loose wires to existing wires out of the way. i used small ties because they are more pliable, and less likely to cut into the wires.
i ordered this set
https://www.diodedynamics.com/fr-s-b...up-module.html
to relocate the turn signals to tails, and use the clear reflective housings for brighter backup bulbs.
i plan to fill the brake light hole with honeycomb mesh like this: https://www.ebay.com/itm/Universal-B...19.m1438.l2649
neilvosko is offline   Reply With Quote
Old 11-27-2017, 06:42 PM   #2
neilvosko
neilvosko's Avatar
may use this for mesh
https://www.walmart.com/ip/Frost-Kin...&wl13=&veh=sem
Old 11-27-2017, 06:45 PM   #3
neilvosko
neilvosko's Avatar
or
https://www.homedepot.com/p/Frost-Ki...X620/202518614
**PHASTEK** Rear Fog Light/Brake Light Kit for the Scion FR-S and Subaru BRZ PhastekSport Exterior Parts - Lighting 57 07-10-2017 08:14 PM
Rear "carbon fiber" oem diffuser removal ReaperBRZ DIY (Do-It-Yourself) Guides 1 08-12-2016 02:26 PM
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 02:23 PM
Rear Bumper "diffuser" Removal sw20kosh DIY (Do-It-Yourself) Guides 6 07-31-2013 03:24 PM
rear brake light in the rear fog light section FR-Shadow Cosmetic Modification (Interior/Exterior/Lighting) 34 12-13-2012 10:52 AM
