Old 07-29-2019, 10:31 AM   #1
Dylon
Drives: Scion FR-S
Key Fob and Door Controls Not Working
So recently on my 2013 Scion FR-S, the key fob has been working off and on. If
I sit there and spam the button enough, it'll usually work; other times it works on the first try like it should. But I've also discovered the unlock button on the door controls(both doors) is not working, but the lock button is.
Any suggestions for how to fix this? I think it might be the battery in the key fob, but that wouldn't explain the door controls not working.a
Dylon is offline   Reply With Quote
Old 07-30-2019, 02:20 AM   #2
humfrz
Yep, change the battery in the FOB.
The other problem sounds like the switch is sticking. I'd suggest you take it out and clean the contacts.
humfrz
ATEQ QuickSet and Passenger Door/Window Controls brz182 Issues | Warranty | Recalls / TSB 10 05-08-2019 01:01 AM
Door speakers not working JRBEL Electronics | Audio | NAV | Infotainment 11 11-11-2017 03:40 AM
Driver side window controls not working clflorida Electronics | Audio | NAV | Infotainment 9 08-12-2017 04:42 PM
Door Subs Not Working? TurboBRZ Electronics | Audio | NAV | Infotainment 7 07-28-2015 01:04 PM
Door handle and seat controls are stiff radroach Issues | Warranty | Recalls / TSB 0 07-18-2013 06:54 PM
