Old 10-16-2017, 01:41 PM   #1
JRBEL
Drives: Scion fr-s 2015
Door speakers not working
HI,
so I bought this 86 salvage from Miami on a auction site and exported it to Caribean and upon arrival I found out that the door speakers does not work , after bodywork and spray was done thought I'd look more into it and started to do some researching , first suggestion I saw was to see if the AMP fuse was blown , it wasn't(even switched it with the spare one). then they told me if i'm sure that my door speakers are there, I open the door panel and they was there , maybe they are blown ? tested it with a battery and its working fine , so the problem sits at the AMP , but how can a OEM AMP be defective or blown ? even the head unit is OEM so what other could it be ? I don't think the AMP is blown on a 2015 car with 21k miles on it . you guys have any other suggestion I can try to find out the problem ?
due to it being bought off an auction site I have no idea who to previous owner was to see what he could've done to cause this .
let me know please.
Thanks
(English is not my native language so excuse the bad writing)
btw head unit is Pioneer AXCP-Q15U T10028
Picture of the car if you are interested:
https://imgur.com/a/DmYAs
edit: all of the threads I saw here was either fixed by a fuse or there door speakers was not working after doing some mods with either replacing the HU or adding subs.
JRBEL is offline   Reply With Quote
Old 10-16-2017, 03:35 PM   #2
darko
Drives: RAVEN FRS
use a multimeter and check the continuity of the speaker wires. Could be frayed wires, or check the engine compartment fuses.
darko is offline   Reply With Quote
Old 10-16-2017, 04:29 PM   #3
JRBEL
I don't see any fuse relatable to audio in the engine compartment.
here is the diagram : http://www.autogenius.info/scion-fr-...e-box-diagram/
the AMP fuse is not blown and the radio fuse is not either otherwise radio would not work right ? might have to check.
I will be checking for frayed wires ,although I highly doubt it but you never know what the previous owner might've been doing .
Thanks for the reply
Old 10-16-2017, 04:37 PM   #4
Chimera
Drives: FRS
check the fuse box in the drivers compartment
should be under the steering wheel
Old 10-16-2017, 05:02 PM   #5
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
Here is the interior fusebox diagram from the owners manual.
fx1mark is offline   Reply With Quote
Old 10-16-2017, 06:49 PM   #6
JRBEL
Both fuse is good .. even swapped the AMP one with a spare and still nothing .. if it was frayed wire i think i could atleast get some hissing sound here and there . They dont work at all .anyway to check if the amp is good or not ? To see if it turns on ?
Old 10-16-2017, 11:04 PM   #7
CraigVM
Drives: Car Collector
Could be an issue up at the dash speakers
Could be an issue up at the dash speakers. Based on what I learned from the following video link, the front channel wires first go up to the dash speakers them down to the door speakers. The kit they sell has a connector that maintains that jump down to the door speakers when replacing those up on the dash. Perhaps someone replaced the dash speaker / speakers and dropped the connection down to the door by mistake
[ame="https://www.youtube.com/watch?v=yUE3GdqHSkE"]https://www.youtube.com/watch?v=yUE3GdqHSkE[/ame]
CraigVM is offline   Reply With Quote
Old 10-18-2017, 01:47 PM   #8
JRBEL
checked my dash speakers and while they are OEM , my tweeters are not working . maybe that's why the door speakers are not working ? cause when you disconnect the tweeter , the mid will stop working too .
so if I replace my tweeters , my door speaker will start working again ?
ill have to order these parts and wait like 2 weeks for them to arrive here so any insight can help so I don't have to waste money and tax on something that's not the problem.
Thanks
Old 10-19-2017, 02:22 AM   #9
CraigVM
I believe it is the stock connector of tweeter / mid that jumps the signal to the wires going down to the doors, not the tweeter or mid itself. So even a blown mid or tweeter up on the dash should not effect the signal getting down to the door speakers. My thoughts were that the previous owner may have changed the dash speakers and caused the problem.
Before purchasing any items to fix the issue, I would do some basic troubleshooting to determine what it is that needs to be fixed.
Old 11-10-2017, 03:04 PM   #10
JRBEL
Amplifier/door subs problem Hi,
I own a 2015 scion fr-s which I bought salvage and upon arrival my door speakers and tweeter was not working.
I checked the fuse and its not blown.
tested the wires to see if electricity is getting there with a electrical tester & test leads and everything is fine but electric is not getting at my door speaker connector .I even bought a used amplifier and switched it and it's still not working. ( when the power wiring is on the AMP should the AMP pins light the tester ? cause it was not doing that but I don't know very well how those works )
at this point I'm thinking that maybe after the accident they took out the aftermarket Headunit and put the OEM back and maybe did not plugged it right ?
I did inspect it and everything looks fine but there is 3 connector that's open and I wanted to know if maybe one of them leading to the AMP is missing ?
can someone please help me solve this .
its driving me nuts not having bass and I don't want to spend a fortune on buying a new amp with a sub and doing all the wiring just for it to work cause I don't really care about a beast sound, (not to mention paying freight forwarder and import duty tax which is 36% in the Caribbean)all I need is my OEM door subs to work and i'll be happy.
sorry for the bad English , not my native language.
I will post link with the pictures of my headunit and the connectors and amp.
Thanks
https://imgur.com/a/StZep
decided to update this thread .
I also bought some used tweeters to see for sure but problem remains the same .
the amp is not powering the speakers .
when I test the power wire on the connector the electrical tester lights up so power is getting there.
any1 have the diagam of the headunit back connectors? there's 3 spot open and I don't know if that is normal.
Old 11-10-2017, 09:43 PM   #11
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Here's an image of the wiring.
As you can see, one set is amplified, one is not. They are all based off the same wiring and connector, so the headunit is not the issue. Identify which wires are not supplying signal, test their continuity, and go from there.
sharpsicle is offline   Reply With Quote
Old 11-11-2017, 02:40 AM   #12
DaveB.inVa
Drives: 2016 BRZ Premium
Do you have the amp turn on signal working or is it connected?
One of the frequent questions I've seen on here are the amplified speakers not working due to the amp turn on signal not being connected to the aftermarket head unit.
Don't worry, your English is fine, English is my native language and you're doing better than I am!
DaveB.inVa is offline   Reply With Quote
door speakers not working number1Tango Electronics | Audio | NAV | Infotainment 23 04-03-2022 07:03 PM
Door speakers not working after new head unit install lsr78 Electronics | Audio | NAV | Infotainment 17 04-27-2021 04:23 PM
Door speakers not working but the rears are mm10 Electronics | Audio | NAV | Infotainment 11 01-14-2017 02:59 AM
Get Big! (door speakers) Shankenstein Electronics | Audio | NAV | Infotainment 3 06-10-2014 02:55 PM
BRZ door Speakers bbs15 CANADA 3 05-23-2013 05:29 PM
