Old 07-28-2019, 07:38 PM   #1
dynarun55
dynarun55's Avatar
Drives: 2015 midnight blue limited edition.
Question Clutch problems on BRZ after 70k miles
Alright. I have read multiple threads about the TOB problem. And it sounds like I just ran into it. Would really like your opinion on getting a excedy stage 2 clutch kit. Will this fix potential TOB problems in the future ? Should I also invest in a stronger fork and pivot ?? The hydraulic bearing looks sold out and honestly not on my option list.
Also I had my local mechanic take a look at my car and said that it looked the clutch was not disengaging completely. I have an appointment with the dealership on Tuesday. Is it even worth going ? I don't have any extended warranty anyway.
dynarun55 is offline   Reply With Quote
Old 07-28-2019, 08:21 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
no, a heavier clutch will actually be tougher on the tob. ...because it's heavier.
stock stuff is fine.
I question the talent of a mechanic that would miss or ignore a failed tob, or not be able to figure out this issue in five minutes.
Describe exactly what you are experiencing.
Old 07-28-2019, 10:00 PM   #3
dynarun55
dynarun55's Avatar
At low rpm, when I depress the clutch I hear a noise that sounds a gas cylinder being vented. Like a shhh noise. I can't hear anything once I'm on the highway so that gives you an idea on the decibel level.
brz, clutch, tob
Clutch spring delete problems MG86 Engine, Exhaust, Transmission 11 07-20-2020 03:19 PM
FR-S Extreme Clutch Problems Japanese_Carbon Issues | Warranty | Recalls / TSB 19 03-07-2020 02:34 PM
Clutch problems? uEih Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 04-03-2019 04:21 PM
Clutch problems please help MelvinKennyG Engine, Exhaust, Transmission 48 09-14-2016 07:32 PM
New Clutch Job, New Problems... RUEN_86 Engine, Exhaust, Transmission 4 12-28-2015 05:13 PM
