Old 07-23-2019, 11:12 AM   #1
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
E85 oil change interval
Yes, I searched and came up snake eyes. Is there a consensus on how far to go between changes using E85. I think I saw 3000 written somewhere but not certain. I'm about to drop my 0w30 Mobil 1 at 4,000 and get analysis, but I just started using E85 so all that will change next time.
Qwimby1 is offline   Reply With Quote
Old 07-23-2019, 01:00 PM   #2
humfrz
I would say the same as using gasoline - fer sure.
humfrz
Old 07-23-2019, 10:00 PM   #3
Dake
Dake's Avatar
It's deep in one of either the E85 or OFT threads here, but some have recommended more frequent oil changes because the E85 can thin the oil.
Others have supposedly gotten Blackstone reports that show they're good to go for normal intervals. So... who knows?
Dake is offline   Reply With Quote
The Following User Says Thank You to Dake For This Useful Post:
BEZO760 (07-24-2019)
Old 07-26-2019, 01:19 AM   #4
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
This may be helpful:
https://forums.nasioc.com/forums/sho....php?t=2482917
scion fr-s is offline   Reply With Quote
Old 07-26-2019, 02:15 AM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
You should be fine for regular interval if you use API SN Resource Conserving, which is formulated for use with ethanol
EndlessAzure is offline   Reply With Quote
Old 07-26-2019, 05:04 PM   #6
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
blackstone told me to do 4500 this change since 3000, and 4000 looked good
Breadman is offline   Reply With Quote
New Oil Change Interval for 2015s? tomkozski Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 50 02-12-2018 01:13 AM
Oil Change Interval BunnyRZed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-01-2018 09:58 PM
Oil change interval tayj89 Other Vehicles & General Automotive Discussions 3 07-21-2016 10:21 AM
10K oil change interval on 2015's? torqdork Scion FR-S / Toyota 86 GT86 General Forum 29 08-13-2015 01:01 AM
Oil Change Interval Change (Subaru recommended) Flow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 09-10-2014 07:27 PM
