Old 07-11-2014, 02:30 PM   #1
tomkozski
Drives: 2017 WRB BRZ w/ PP
New Oil Change Interval for 2015s?
Noticed that the oil change interval for 2015 BRZs (and I'm assuming FR-Ss too) has changed to every 6,000 miles. 2013-2014 had the interval at every 7,500 miles. I'm not aware of any changes to the engine or the oil type for the 2015 model. Anyone know why the change was implemented, and should owners of 2013/14 twins follow the new intervals?
tomkozski is offline   Reply With Quote
Old 07-11-2014, 03:09 PM   #2
FR-S Matt
I say check your own oil and make that decision. Could be they want more money in their service department for oil changes. I would change at that interval for FI. N/A on good full synthetic oil can go 10k depending on how the car is driven.
My 2 cents.
Old 07-11-2014, 06:11 PM   #3
Malt
Drives: 2015 WRX
You could start testing your oil like several of us do and use that as a guide as to when to change your oil. Its not unheard of to go 10k+ miles between oil changes. Personally oil and filters is cheap enough its not worth running ultra long drain intervals.
Malt is offline   Reply With Quote
Old 07-13-2014, 01:17 AM   #4
technoid
Drives: Silver BRZ
The 7500 scares me. Granddad always said to change it at 3000 no matter what.
They didn't have these synthetic oils at that time, but still I'm a bit concerned about that. The boss races late model's and says to change the filter at 5k and oil at 10k, in the street car, after every race in the race car.
technoid is offline   Reply With Quote
Old 07-13-2014, 01:58 AM   #5
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
Modern engines and oils are dramatically different from granddad's. You can easily go 10k or more on most modern engines with synthetic oil if the engine is seeing fairly light duty (lots of fully warmed up highway miles). I would tend on the shorter side if you're tracking the car or driving really aggressively (or using it on a lot of short trips), but for many people, the long oil change interval is just fine.
chrisl is offline   Reply With Quote
Old 07-13-2014, 03:17 AM   #6
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
We're in a different era from your granddad. Our engines are fuel injected, not carb, our engines are engineered better and are tested to last longer, and our motoroil is different from your granddad's era as well.
We have the technology !
N1rve
Old 07-14-2014, 09:13 AM   #7
bluesubie
No changes with the engine or oil. Speculation is that it is because of the oil guzzling engines that are in some of the other Subaru's (the FB engine) so that dealer's can keep a closer eye on oil level. There was a TSB for the oil control rings and folks with major oil consumption are having major engine work done.
The DIT 2.0 turbo in some models (Forester) seems to be pretty harsh on oil with fuel contmination as well.
-Dennis
bluesubie is offline   Reply With Quote
Old 07-14-2014, 09:41 AM   #8
sluflyer06
Drives: 2014 BRZ Ltd - DGM
My 2 cents.
You do know the FACTORY writes maintenance schedule not the dealers right? and that the factory doesn't get paid to do the oil changes.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
Old 07-14-2014, 09:48 AM   #9
FR-S Matt
I've also been using synthetic oil for years and you're wasting money if you change the oil that early. Goes right back to checking your oil with your own eyes. My last 4 oil changes in my car weren't even real dark at 9000 miles, but that will change soon when I go S/C.
Three best things you can do for your car: Use good gas, use great oil, and check your fluids constantly.
Old 07-14-2014, 09:58 AM   #10
viscositosis.rex
Drives: Currently 2018 Taco
I am not sure exactly what to make of this just yet, but this is significant news. An owner needs to be able to set up a maintenance plan that they can be confident with. Why doesn't every manufacturer just purchase Mazda's high-temperature technology for dealing with GDI-caused intake valve deposits?
viscositosis.rex is offline   Reply With Quote
Old 07-14-2014, 03:25 PM   #11
bluesubie
Your maintenance schedule was written by Fuji Heavy Industries? Wow! Is it in Japanese or English?
I think Subaru should have used Toyota's DI technology on the WRX/Forester like they did on the BRZ/FR-S. When the oil lab tells you the oil is shot at 1,200 miles due to fuel contamination, you've got a problem. Meanwhile, most manufacturers are extending their intervals on xW-20's.
-Dennis
Old 07-14-2014, 03:31 PM   #12
JasperNoone
Drives: Car
So is this OCI change retroactive? Not that I do 7.5K mile changes anyway, usually closer to 6K.
JasperNoone is offline   Reply With Quote
Old 07-14-2014, 03:36 PM   #13
bluesubie
Officially, no. Unofficially, it probably depends on the dealer IMO.
I suspect some dealers will adopt 6k across the board to make it easier for themselves to remember. Of course, you're only required to change according to the warranty booklet.
Some more info:
Dear Mr. bluesubie
Thank you for taking the time to contact Subaru of America, Inc. regarding our recommendations for engine oil.
Yes, for the 2015 models, we will be recommending oil changes every 6,000 miles or 6 months, whichever comes first. Information as to why this change is being implemented is not available. Such information would be proprietary within Subaru. ...
http://www.bobistheoilguy.com/forums...a_cuts_OCI_to_
-Dennis
Old 07-14-2014, 03:50 PM   #14
JasperNoone
Drives: Car
Interesting, a poster suggests there was a valvetrain change for 2015. Not sure I've seen any info on that.
Oil Change Interval BunnyRZed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-01-2018 09:58 PM
Tire Rotation Interval Questions HunterGreene Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-03-2016 09:40 PM
Motul Gear300 75W90 oil change interval? levinchow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-09-2014 11:20 AM
Oil Change 86 FRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-18-2013 10:00 AM
First Oil Change Jehuty77 CANADA 14 08-09-2012 11:54 PM
