CANADA Canada
Old 07-18-2019, 07:49 AM   #1
lc300
Drives: 2014 BRZ Sport Tech
Looking for Best Shop for Engine Rebuild
After dealing with rough idle issues and cylinder 3 misfire codes, compression test showed low compression in cylinder 3. The car was a 2014 and had 80000km. I’m looking for a shop that can rebuild the motor.
Anyone have any recommendations?
lc300 is offline   Reply With Quote
Old 07-18-2019, 08:36 AM   #2
wparsons
wparsons's Avatar
Getting a good used engine installed will likely be cheaper than having your current one rebuilt, but a good shop will give you the options if you talk to them.
If you're close enough to Hamilton, I'd suggest NV Auto.
flickr
Old 08-28-2019, 02:19 PM   #3
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Investigate CanJam. Not sure if they touch stock though.
They reincarnated a buddy's modified STI engine and he's thrilled.
Muskoka800 is offline   Reply With Quote
Old 10-05-2019, 01:12 AM   #4
JDM_Import
Drives: Boosted Toyobaru
Look up Seven Automotive... they specialize in subaru engines and are good to go
JDM_Import is offline   Reply With Quote
Old 10-05-2019, 10:03 AM   #5
RFB
RFB's Avatar
Drives: FRS
They do rebuild stock short blocks for high h.p.,
They have a lot of boxer experience and are known for reliable racing engines.
RFB is offline   Reply With Quote
Old 10-09-2019, 05:11 PM   #6
86driftcar
86driftcar's Avatar
+1 SevenAutomitive
86driftcar is offline   Reply With Quote
Dealer has had FRS in shop for 3 weeks for engine rebuild, advice? SGP90 Issues | Warranty | Recalls / TSB 48 05-23-2018 07:55 AM
P0335 after engine rebuild Greg555 Issues | Warranty | Recalls / TSB 10 12-27-2017 11:32 PM
Engine won't start after rebuild septonb Engine, Exhaust, Transmission 7 05-26-2017 10:48 PM
For the engine rebuild gurus puma Engine, Exhaust, Transmission 9 09-08-2016 06:33 AM
any shop in socal rebuild calipers? Dan197 Southern California 1 08-19-2015 07:31 PM
