Old 05-25-2017, 11:45 PM   #1
septonb
Drives: Toyota GT86
Engine won't start after rebuild
Damaged the rod bearings in my GT86. After replacing bearings and rebuilding engine, it turns but won't start, though everything seems to be in order.
Any ideas as to what may be causing this problem?
septonb is offline   Reply With Quote
The Following User Says Thank You to septonb For This Useful Post:
Chaetagnath (05-26-2017)
Old 05-26-2017, 12:20 AM   #2
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
My guess is something wasn't installed correctly. Did you do the install?
Seriously you need a real mechanic not FT86 forum troubleshooting.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 05-26-2017, 02:33 AM   #3
humfrz
Well, your engine needs fuel, air, compression and spark to run.
I reckon at least one of those is missing.
Just start checking for the missing component(s).
humfrz - being a BIG help ......
Old 05-26-2017, 02:36 AM   #4
driftguy
driftguy's Avatar
Drives: In between cars... 2018 Ninja 1000
Based on the limited info humz, that's as helpful as I could be as well. Start with the obvious.
driftguy is offline   Reply With Quote
The Following User Says Thank You to driftguy For This Useful Post:
humfrz (05-26-2017)
Old 05-26-2017, 02:37 AM   #5
humfrz
....... hey ..... we can fix it.
Sort of like if you had enough monkeys typing on enough typewriters for long enough ...... one of them will correctly type out the complete Declaration of Independence........
humfrz
pward08 (03-25-2018)
Old 05-26-2017, 04:52 AM   #6
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Your first step is to figure out what the engine is not getting. Start with the basics. Do a compression test. Test to see if the engine is getting fuel pressure. Test to make sure it's getting spark. Make sure no one stuffed a rag in the air intake.
Old 05-26-2017, 09:48 PM   #7
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Ground not attached on wiring harness?? It could be literally anything.
Check out this article: http://www.autotap.com/techlibrary/dis_ignition.asp
sly is offline   Reply With Quote
Old 05-26-2017, 10:48 PM   #8
FRS Justin
Drives: 2013 Asphalt FRS
1: Is it cranking
2: does it have spark
3: does the fuel pump turn on with key in run position
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
For the engine rebuild gurus puma Engine, Exhaust, Transmission 9 09-08-2016 06:33 AM
engine won't start after pushing it andrew5826 Engine, Exhaust, Transmission 9 09-01-2016 10:34 PM
Sputter/Rough engine at start? iLaw Engine, Exhaust, Transmission 3 10-22-2014 08:21 PM
Engine doesn't start right away Cajun Issues | Warranty | Recalls / TSB 1 02-04-2013 02:09 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
