Old 07-18-2019, 06:21 AM   #1
uchiha
Drives: BRZ 2020
BRZ take 2-3 seconds to start and feels unresponsive below certain amount of fuel
Hello,
I have an 2015 BRZ, recently i noticed that when the fuel level drops below 3/4 the car cranks for 2-3 seconds and than starting.
(It's always starting eventually, never stalled)
I've also noticed some performance decrease in when the fuel level below 3/4.
The weird thing is that when the fuel is above 3/4 everything's just fine.
I took the car to my mechanic and we started a process of cleaning the injectors. He cleaned once, still didn't help so we scheduled to do another cleanup.
I really trust him and he's taking car of my car for a while now,
but what i don't understand is how is it possible that the issue happens only above certain fuel level (3/4) - if the problem is in the injectors.
Any help would be appreciated, Thanks
uchiha is offline   Reply With Quote
Old 07-18-2019, 06:45 AM   #2
86MLR
86MLR's Avatar
Run it up on a dyno if you can
That will tell you more than a shot gun approach, and may end up cheaper
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
The Following User Says Thank You to 86MLR For This Useful Post:
Tcoat (07-18-2019)
Old 07-18-2019, 09:31 AM   #3
mazeroni
Drives: 2013 Scion FR-S Series 10
First, try to answer some of the following. I think it will help provide people with some insight.
Any mods?
How long have you had the car? I see it is a 2015, but is this a new issue, or did you just buy the car?
How old is the battery? - A long crank is usually a sign of a dying battery.
Have you replaced the engine air filter?
Did the weather change recently and get really hot?
Are you running the AC on startup and while driving?
Are you running 93 or higher?
Did you switch to a different brand of fuel recently?
Have you tried unplugging the battery overnight and plugging it back in to reset the car?
After clearing up those basics, then I would get into injectors and other stuff.
mazeroni is offline   Reply With Quote
The Following 2 Users Say Thank You to mazeroni For This Useful Post:
soundman98 (07-18-2019), Tcoat (07-18-2019)
Old 07-18-2019, 09:33 AM   #4
Not sure if a dyno will tell you much.
I would think it is a fuel filter issue if it is fine when the tank is full. Could be in the evap system as well though.
Edit: and what Maz said!
Old 07-18-2019, 09:52 AM   #5
uchiha
Drives: BRZ 2020
Any mods? - no
How long have you had the car? I see it is a 2015, but is this a new issue, or did you just buy the car? - I have it around 6 months, started 2 months ago.
How old is the battery? - A long crank is usually a sign of a dying battery. - They have checked the battery, seems it's ok.
Have you replaced the engine air filter? - Yes, recently as part of 60K services
Did the weather change recently and get really hot? - It's hot, but always was :-)
Are you running the AC on startup and while driving? - not at start up, i tend to turn it off before turning off the car. While driving - yes.
Are you running 93 or higher? - 95
Did you switch to a different brand of fuel recently? - No
Have you tried unplugging the battery overnight and plugging it back in to reset the car? - i didn't but the mechanic said he's checked it and the battery is fine.
Thanks for the reply, please see answers above ^
Old 07-18-2019, 12:13 PM   #6
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I think you misunderstood the part about unplugging the battery that @mazeroni mentioned.
Unplug the battery from the terminal and leave it like that overnight. Plug it in in the morning, start the car, and allow it to idle for 10 minutes. This will allow the ECU to relearn the idle and throttle.
EndlessAzure is offline   Reply With Quote
Old 07-18-2019, 01:14 PM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
or you can unplug it and then stand on the brakes for a minute or so. That should drain the residual out of the system.
Old 07-18-2019, 03:00 PM   #8
uchiha
Drives: BRZ 2020
I'll suggest it to my mechanic when i'll take the car to the service again, thanks
Old 07-18-2019, 06:55 PM   #9
Grady
Grady's Avatar
If it is related to fuel level I would start with the fuel pump/inspect inside the tank.
Which packages/models/years came with push start, LED dash/fuel gauge? Heated seats? Scremin@ATS BRZ First-Gen (2012+) — General Topics 11 03-25-2019 05:15 PM
E85/Flex fuel hard start? iketiak Engine, Exhaust, Transmission 18 01-14-2017 07:12 PM
Flex Fuel cold start stumble post_break Software Tuning 12 04-02-2014 01:40 PM
0-60 in 6.1 seconds? SUB-FT86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 57 01-04-2012 10:14 PM
