Old 03-24-2019, 09:01 PM   #1
Scremin@ATS
Drives: 2017 86, 94 Supra TT, 93 MR2T,90GT4
Which packages/models/years came with push start, LED dash/fuel gauge? Heated seats?
Trying to narrow my searches. So far I’ve seen the dash in a 2019 Limited Series.grey as well as a TRD 86. When and how was it available?
Scremin@ATS is offline   Reply With Quote
Old 03-24-2019, 11:17 PM   #2
edwardl
Drives: 2018 BRZ
The 2017+ remodel added those
edwardl is offline   Reply With Quote
Old 03-25-2019, 12:33 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
all limited models from 2013 had push button start, led lighted gauges, and heated seats.
there has never been an 86 that used incandescent bulbs for any of the gauge clusters...
Old 03-25-2019, 10:52 AM   #4
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
I believe the OP was referring to the "Multi-Information Display". Toyota first made this available on the 2017 860SE and I believe the GT models in 2018+. Not sure about the BRZ models.
LimitedSlip is offline   Reply With Quote
Old 03-25-2019, 10:54 AM   #5
imped4now
Drives: '17 BRZ PP - '17 FoRS
I believe all 2017+ BRZ's have that. My 2017 Limited w/PP obviously has it all.
imped4now is offline   Reply With Quote
Old 03-25-2019, 11:46 AM   #6
maslin
Benz Tech
Drives: 2017 BRZ Premium
Limited only. Premium has a standard cluster and blade key.
maslin is offline   Reply With Quote
The Following User Says Thank You to maslin For This Useful Post:
Tcoat (03-25-2019)
Old 03-25-2019, 12:01 PM   #7
The 86 GT has everything the BRZ Limited does. including the info display.
Old 03-25-2019, 12:13 PM   #8
maslin
Benz Tech
So
BRZ Premium = 86
BRZ Limited = 86 GT
BRZ tS= 86 TRD
Or close to it. As far as electronic options and fancy add on body parts go.
Tcoat (03-25-2019)
Old 03-25-2019, 12:20 PM   #9
Originally Posted by maslin View Post
So
BRZ Premium = 86
BRZ Limited = 86 GT
BRZ tS= 86 TRD
If Scion had still been the badge there would never have been a GT trim level due to their "One Trim One Once Price Point policy". There would have been the RS versions that would have had all the features though.
maslin (03-25-2019)
Old 03-25-2019, 02:00 PM   #10
yurikaze
yurikaze's Avatar
Drives: 2018 BRZ tS (CBS), AE86 GT-S, MA70
Here's what you'll look for:
86 860 edition
86 GT
BRZ Limited
BRZ Limited Performance Package
BRZ Series.yellow
BRZ Series.grey
BRZ 50th anniversary edition
BRZ tS
However, the 86 TRD doesn't have heated seats. so it's off the list if you want those.
yurikaze is offline   Reply With Quote
The Following User Says Thank You to yurikaze For This Useful Post:
Tcoat (03-25-2019)
Old 03-25-2019, 02:27 PM   #11
86 860 edition
86 GT
BRZ Limited
BRZ Series.yellow
BRZ Series.grey
BRZ tS
There are a few FRS RS/Special editions that have all the stuff except the display as well.
Old 03-25-2019, 06:15 PM   #12
soundman98
soundman98's Avatar
i figured he was, i just get irritated every time someone calls any screen 'led'. so i took the technical route.
i also make fun of my grandfather because he constantly is saying he's a 'yuber driver' for relatives.
LimitedSlip (03-25-2019)
OEM heated seats in aftermarket seats Jive Turkey Cosmetic Modification (Interior/Exterior/Lighting) 6 06-09-2024 01:31 PM
FS: STI engine start push start OEM plug and play sokol Interior Parts (Incl. Lighting) 5 06-13-2019 03:12 PM
Dash Hole Filler next to push to start Lord Peth Cosmetic Modification (Interior/Exterior/Lighting) 17 05-30-2014 10:21 PM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 07:06 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
