Old 07-09-2019, 09:35 PM   #1
BEZO760
Drives: Blue 2016 SCION FR-S
Help with slight wheel rubbing.
Hey all so I finally installed my HKS Hypermax IV GT coilovers. I left about a finger of space to prevent rubbing. When I turn my wheel all the way to the right/left I can put my pinky between the gap it makes. I do want to go lower tho, like half an inch lower. I'm certain that if I do go lower I will in fact start rubbing.
My question is, will spacers help prevent this?
Wheel set up is as follows; WedsSport TC105n 17x9.5 with General G Max RS 245/40/17. I'm trying to go for a look with zero gap, I can put my thumb between my wheel and fender at the moment.
BEZO760 is offline   Reply With Quote
Old 07-10-2019, 12:16 AM   #2
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
What are the suspension details? Any LCA, camber bolts etc.?
Will BRZ is offline   Reply With Quote
Old 07-10-2019, 01:45 AM   #3
Skyehigh55
Drives: 2017 Pure Red BRZ w/ Perf Package
Wheel set up is as follows; WedsSport TC105n 17x9.5 with General G Max RS 245/45/17. I'm trying to go for a look with zero gap, I can put my thumb between my wheel and fender at the moment.
I believe your wheel sidewall profile is too large which can induce rubbing since the tire is meatier and taller. I thought the recommended aspect ratio for anything 9.5 wide is only 35 or 40’s, as 45’s becomes a bit too tall for the inner linings.
The difference between a 245/35 and 245/45 is huge according to the wheel calculator at http://www.ft86motorsports.com/wheelitfit/
You might be able to dial in more negative camber to reduce the rubbing depending on where it might contact but I’d look for 245/35’s since you stated you want to go even lower. Should solve your problems as many run that tire size with no problems at all and many are able to slam.
For what it’s worth, a 245/35 tire will also lessen your speedometer error too since it’s more in line with the stock size (215/45). Hope this helps!
Skyehigh55 is offline   Reply With Quote
Old 07-10-2019, 08:24 AM   #4
maslin
Benz Tech
Drives: 2017 BRZ Premium
245/40r17, not sure I’ve ever seen a 245/35r17.
If you want the slammed zero gap flush boi look it’s going to rub.
maslin is offline   Reply With Quote
Old 07-10-2019, 10:35 AM   #5
BEZO760
None yet. Just coilovers. I'll be getting a camber kit in the near future just so I can run about - 2.5 camber and so I can have a perfect alignment.
Old 07-10-2019, 10:38 AM   #6
BEZO760
I posted the wrong size on my first post. Dunce. It's actually 245/40/17. Not 245/45/17
Old 07-10-2019, 10:46 AM   #7
BEZO760
I took some pictures to help see what I've been describing. Hope it helps!
I would love to be able to lower my car about 3/4ths to a full inch.
Old 07-10-2019, 10:50 AM   #8
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Which offset do your wheels have? What's the location you're concerned about rubbing? Outside edge of the tread or inside edge or something else?
timurrrr is offline   Reply With Quote
Old 07-10-2019, 11:17 AM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Spacers will make it worse. Adding negative camber will help as pointed out earlier. If you go really low you will still rub the fender liner. Mine rubbed the fender liner in the front under hard cornering on 245/40/17 17X9 +38. I was around -2 with no wheel gap.
Old 07-10-2019, 11:49 AM   #10
BEZO760
Offset is +35. And inside edge.
Old 07-10-2019, 11:51 AM   #11
BEZO760
Seems like we have similar wheel setups. Do you have a picture I can see? Only difference in our set up is the offset. You have a +38 whereas I have a +35. Knowing what you know about your tires would you say it's safe to lower mine 3/4ths of an inch?
Old 07-10-2019, 12:18 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don’t have a static shot of my car that low. I believe this is around -1 5/8 front and -1 3/8 rear.
I think another -3/4 on your car might be a little too much. Another half would probably be okay. When you go too low with this car it is into the bump stops a lot and makes the ride a bit harsh. We don't have much bump travel to begin with.
Old 07-10-2019, 12:23 PM   #13
BEZO760
Thanks for the advise man! I think ima lower it another half inch and see how that goes for a month or so. One more thing. I know an alignment is needed when coilovers are switched out, I got one, but lowering it 1\2 inch won't require an alignment right? Since the coilovers are already on
Old 07-10-2019, 12:33 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Lowering will effect alignment. More so in the rear then the front. The car will likely still track straight, but both ends will gain negative camber. It will toe the front in a touch, and the rear out a touch. I don't know how much another half inch will change it, it could be negligible.
Slight front wheel bounce on sharp right turn? iceblaze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 04-09-2018 12:43 PM
will this wheel and tire combo fit with stock suspension without rubbing? Andreasbrz14 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 05-23-2017 04:25 PM
Slight buzz at 1,500 RPM ericmpena Engine, Exhaust, Transmission 5 05-02-2014 08:35 AM
How to tell if front wheel is rubbing against strut? shu5892001 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 05-08-2013 09:54 AM
LIST: Non-rubbing 17" wheel & tyre packages ft_sjo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 04-28-2013 06:56 AM
