Drives: 2014 Scion FRS MT,2017 Toyota 86 AT
Slight front wheel bounce on sharp right turn?
Hey all,
I have a 2017 Toyota 86 with Tein Flex Z coilovers, Perrin endlinks, and TRD sway bars. I've also had my cars corner balance/alignment/suspension adjusted professionally. It is lowered a bit. However, I've notice that on some sharp right turns which have a slight bit of downhill grade, my front passenger wheel/suspension feels like it bounces or lumpy once or twice before it corrects itself. It happens whether I accelerate into the corner or not. Does anyone possibly know what this could be/how to correct? Perhaps its just the road thats bad or uneven? Thanks Last edited by iceblaze; 04-06-2018 at 10:32 AM. |
#2 | |
![]() humfrz |
How much camber?
I've noticed some odd feelings while turning over uneven roads at slow speeds when you start running more than about -2 degrees up front. |
Nah I'm with hmfrz, you stiffened the cars suspension up quite a bit, more feedback from the road now
If it bounces and oscillates excessively after a bump, that means it needs more damping. The inside (unloaded) wheel should be able to handle a bump without bouncing excessively. Depending on your coilovers, just a few clicks stiffer might do it, but this very much depends on your coilovers and how they adjust.
If setting your coilovers stiffer doesn't help, or makes things worse enough in other ways (too harsh, compromised balance) then you may just have to take a different line through the corner. - Andrew |
I would try your stock front endlinks again. My Perrin endlinks would bind all the time and it made me question why they put a bushing style endlinks on a rotating strut.
| Turn as tail timing not matching with the front turn signals | NahumCC | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-03-2016 10:40 PM |
| Steering wheel issue---left turn lighter than right turn!!! | xingxingtjf | Issues | Warranty | Recalls / TSB | 12 | 10-14-2015 06:47 PM |
| Help! Slight vertical bounce with new wheels/tires | SilverTipp | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 10-06-2015 11:48 AM |
| Greddy SP Elite + EVS Evasive Motorsports Front Pipe = Slight Boxer Rumble | sidnacious | Engine, Exhaust, Transmission | 22 | 07-30-2015 07:47 PM |
| Sharp grease lines | Tiremonkey0824 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 10 | 09-24-2012 01:29 PM |
