Old 07-08-2019, 03:14 PM   #1
Silverz
Drives: Black frs
Battery replacement oem
Anyone know where to get a oem battery.
I think it’s a Panasonic.
If not, what is everyone using as a replacement?
Silverz is offline   Reply With Quote
Old 07-08-2019, 03:36 PM   #2
humfrz
I've found Interstate batteries work well for every day use.
humfrz
g e (04-01-2023)
Old 07-08-2019, 03:37 PM   #3
extrashaky
Drives: 2014 BRZ Limited
My OEM battery was crap. It was so weak the engine would stumble when I turned on the lights, and the lights would dim if I rolled down a window. I thought that was normal behavior, that we just had a weak alternator. If I forgot to remove my OBDII adapter when I left the car at the airport while out on a trip, the battery would be dead within four to five days.
I finally replaced it with a Duracell AGM battery from Sam's Club. Instantly everything electrical worked better. No more engine stumbling when I turned on the lights. I accidentally left the trunk open overnight for ten hours and figured it would be dead. It started right up without any hesitation.
The only drawback is that the AGM battery is heavy, but unless you're on a weight reduction scheme for racing, who cares. If I were to buy another one, I'd replace that Painasonic right off.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
dnieves (07-10-2019), Vic4uf (07-14-2019)
Old 07-08-2019, 03:41 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Why do you want an OEM battery????? That's one of those things that will not add value to a car, no matter how old/original it is. Please don't
[ame]https://www.youtube.com/watch?v=nkVzlOFOxSY[/ame] This is a video I made of the difference it made on my car.
The Following User Says Thank You to DarkPira7e For This Useful Post:
MJones_RB (07-08-2019)
Old 07-08-2019, 03:44 PM   #5
Any battery of the right size and cranking power will work just fine. Go to any automotive parts counter and tell them what you drive and they will give you a whole price range to select from.
Old 07-08-2019, 03:51 PM   #6
extrashaky
Well, yeah, but you have to admit they're not all the same quality. I used to use WalMart batteries until I had two 36 month batteries in a row die after two to two and a half years each. I've got a DieHard AGM in my Jeep that's been there for years now with no sign of giving up.
Old 07-08-2019, 03:52 PM   #7
That is where my statement of "a price range" comes in. All will do the job though.
Qadthane (07-09-2019)
Old 07-08-2019, 04:09 PM   #8
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
I'm the odd one here:
I'm quite happy with my Walmart Valuepower battery purchased May 2018. Current price for that battery is $48.88. Made by Johnson Controls.
Group size for our car is group 35.
I thought that might not fit (it's height [as stated online]) so I picked a slightly smaller, group VP-26R, which most likely weighs less as well.
Dimensions they state online not always correct...so the bigger group 35 most likely will work in our model vehicle.
For the price of an Optima Red Top I can have four of the above...
ToySub1946 is offline   Reply With Quote
Old 07-08-2019, 04:12 PM   #9
Silverz
Drives: Black frs
Anyone heard of Remy batteries? How good are they?
The oem is still running good on mine. I’m right at 4 years. Car is about 5 years old. Bought a ‘15 at the end of ‘15.
Figured it was getting close and the oem has worked well.
My last two batteries I have bought have been autozone gold batteries and they have been good. Price has almost doubled Since the last time I bought a battery.
I guess I am kind of gun shy on batteries since I put a cheap Duracell one in my lawn mower and that thing won’t hold a charge.
Old 07-08-2019, 05:00 PM   #10
Dake
Dake's Avatar
Used to buy top of the line Die Hards in previous cars which still only last about 4 years down in the Texas heat - but at least they'd get replaced for free the first time and pro-rated the second time.
My OEM batt lasted about 5 years, with none of the issues the OP is reporting, but when it started getting weak I went ahead and snagged one of the Braille lightweights and it's still doing fine a couple years in.
Dake is offline   Reply With Quote
Old 07-08-2019, 05:37 PM   #11
g e
Interstate battery from Costco is faring well. I got over 4 years with OEM. Interstate has a retail outlet not far from house I have used in past for other Subaru.
g e is offline   Reply With Quote
Old 07-08-2019, 08:59 PM   #12
orz
orz's Avatar
Drives: Halo
You could buy an equivalent group 35 battery from subaru/toyota or go aftermarket. I went with the Odyssey PC-680 for the weight savings and the battery pan/tie downs is off a jdm gt86 that I sourced out from subaru parts.
orz is offline   Reply With Quote
The Following User Says Thank You to orz For This Useful Post:
Busybee (07-09-2019)
Old 07-08-2019, 09:17 PM   #13
Decep
Drives: 2013 FR-S Series 10
brands don't seem to matter in my experience with batteries. but warranties definitely do. i always get them somewhere i can easily get an exchange.
Old 07-08-2019, 10:55 PM   #14
radroach
Drives: car
Get a Duralast 26R-DL at autozone. They weigh a little bit less than the stock battery, but still start the car better than the stock battery every did, like almost twice as fast to crank over.
Also you shoulda seen how fast the car started on a brand new 35AGM. WEW. Cranked like a truck. I didn't like how much the AGM battery weighed and so returned it for the 26R.
Battery Leaking - 4th Replacement djrbash Issues | Warranty | Recalls / TSB 23 02-14-2021 11:16 PM
Lithium Ion Battery Replacement Benzin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 06:05 PM
Replacement Battery jasonojordan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 17 01-24-2017 06:15 PM
Car Audio Battery Replacement brzstormtrooper Electronics | Audio | NAV | Infotainment 0 03-23-2016 07:38 AM
Replacement Battery slizoth Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-09-2014 02:04 PM
