Old 07-06-2019, 04:39 AM   #1
kev0
Drives: '14
Brakes feel extremely hard after supercharger install
Flashed my car with the base Moto East tune. Had Sprintex 210 kit installed. I haven't been in the car for 7 days since it was out of service for the install (replacement parts took a while to come).
The first time I tried to step on the brakes, before I start the car, it was extremely firm and took a lot of pressure to depress the brake pedal. What the hell happened? Did I somehow get air in my brake lines or something? Car has not been driven for those 7 days!
I also have ABS and TC light on.
kev0 is offline   Reply With Quote
Old 07-06-2019, 08:21 AM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Is your supercharger feeding the brake booster pressurized air? Your bypass valve may not be working right. Check your manifold pressure when off the gas, it should be in vacuum.
Old 07-06-2019, 10:44 AM   #3
maslin
Benz Tech
Drives: 2017 BRZ Premium
The engine only makes vacuum when it’s running. The booster will store a bit, usually a few presses and then the brakes will be hard.
Assuming all that came apart for the supercharger install the vacuum would have bled off. No vacuum in the booster = manual brakes.
Start the car, are the brakes normal? Then it’s all good. You’ll need scanner for the lights.
maslin is offline   Reply With Quote
The Following User Says Thank You to maslin For This Useful Post:
wparsons (07-09-2019)
Old 07-06-2019, 01:01 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
Another thread, same issues. Time to admit you brought it to the wrong shop and find a different shop to fix everything the first shop screwed up
Old 07-06-2019, 01:22 PM   #5
86TOYO2k17
Drives: 2017 toyota 86
Did you pull the brake booster hose cap off your old manifold and reinstall on back of supercharger manifold brake booster port? Are you running the brake booster to the engine without the check valve? Autos run brake booster to the engine with no check valve, and thus the brake booster port on back of manifold needs to be capped.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
kev0 (07-06-2019)
Old 07-06-2019, 04:50 PM   #6
kev0
Drives: '14
Yes to all of them. Don't know why my brakes are still firm.. ugh. Brakes work fine though during the drive..it's just...pretty hard to press down.
Pressing brakes hard in snow (Terrible Noise) Benschneider06 Issues | Warranty | Recalls / TSB 10 01-20-2016 08:15 PM
Halp! Supercharger extremely loud autograph Forced Induction 15 09-24-2015 04:32 PM
Brakes feel 'stiffer' than usual after pumping 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-14-2014 01:57 PM
How do you feel about stock brakes? SillySaxon Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 09-16-2013 09:26 AM
why does the BRZ's brake feel firmer after a hard stop? chenshuo BRZ First-Gen (2012+) — General Topics 12 05-29-2013 05:32 PM
