Old 05-29-2013, 10:34 AM   #1
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
why does the BRZ's brake feel firmer after a hard stop?
long story short, i was on my way to work and this guy in front of me was gonna go for a yellow light but decided not to. I was behind him so i had to step on the brake HARD to avoid a collision. Right after that, the brake feels significantly firmer. Why? Should i be worried about anything?
Edit: i should probably add that, when i say firm, i mean i didn't have to step on the brake as deep as before for it to engage braking force. Feels like new brakes.
chenshuo is offline   Reply With Quote
Old 05-29-2013, 10:47 AM   #2
s0sl0w
Proud of Boxer
probably burped some air into the reservoir by the cycling action of the ABS perhaps?
s0sl0w is offline   Reply With Quote
Old 05-29-2013, 11:14 AM   #3
GNS
Drives: .
Maybe it's the Brake Assist feature? It helps to apply brake force beyond what the driver can apply with the right foot.
GNS is offline   Reply With Quote
The Following User Says Thank You to GNS For This Useful Post:
M-17 (05-29-2013)
Old 05-29-2013, 11:37 AM   #4
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
The hard braking brought back memories of being at the track, and the pedal is now aroused.
Ganthrithor is offline   Reply With Quote
The Following 2 Users Say Thank You to Ganthrithor For This Useful Post:
KelvinBRZ (05-29-2013), RurumariGhost (05-29-2013)
Old 05-29-2013, 11:55 AM   #5
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
"Should i be worried about anything?"
Yes. You should probably not have had to break hard.
BRZfan is offline   Reply With Quote
Old 05-29-2013, 12:13 PM   #6
s0sl0w
Proud of Boxer
After seeing quite a few of your post I've decided you're a tool. Sometimes people do dumb things in front of you or maybe you were going a bit fast or maybe following too close. Does it really matter why he had to stop quickly? The point is he did stop so quit being an ass.
The Following 5 Users Say Thank You to s0sl0w For This Useful Post:
Cameronghanson (05-29-2013), F-Bomb (05-29-2013), M-17 (05-29-2013), Marchy (05-29-2013), whaap (05-29-2013)
Old 05-29-2013, 12:50 PM   #7
strat61caster
strat61caster's Avatar
It is the vehicle behind who is responsible for keeping a safe following distance. If the car in front of you slams on the brakes for a squirrel, yellow light, small child, or if their tire blows up or engine seizes you NEED to have the space to come to a safe and controlled stop. It's basic driving etiquette not to mention the law, doing so can save lives.
Nobody is perfect, but a reminder every now and then doesn't hurt.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Old 05-29-2013, 01:07 PM   #8
atledreier
Drives: GT86 DGM
Most likely it's just the brakes being up to temperature. The first corner on track the brakes feels like glass, but after the first few hard scrubs they are up to temp and bite like I'm used to. Same thing on the street. Most people never tried brakes that are up to temperature (not boiling of course). The bite can be significant compared to cold brakes.
atledreier is offline   Reply With Quote
Old 05-29-2013, 01:22 PM   #9
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Yea I admit i wasn't keeping enough distance. It was during the morning rush hour i find if i keep enough distance, some other car is going to squeeze into the gap.
So nothing to worry about?
Old 05-29-2013, 02:01 PM   #10
strat61caster
Doesn't seem like it, they'll feel different with temperature changes as well as the brake booster as mentioned.
If it went from "spongy" to rock solid in one stop though there may be some cause for concern, keep paying attention and if it's repeatable or any other signs go to the dealership.
ineedyourdiddly
Old 05-29-2013, 03:56 PM   #11
Ganthrithor
Agreedo. It happens, but ideally it shouldn't.
Old 05-29-2013, 04:09 PM   #12
Wilsonk227
Wilsonk227's Avatar
Drives: Super Vehicular Terrain Vehicle
hmm not sure if it has much to do with it, but check your brake fluids just incase? I'm not a car tech guy but just a suggestion.
ig: @MrWiils0n
Wilsonk227 is offline   Reply With Quote
Old 05-29-2013, 05:32 PM   #13
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
This is correct. Sport brake pads get more friction as they heat up. But if they heat up too much, you'll lose friction. It was your brake pads. Nothing to worry about.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Emergency brake adjustment? F3dzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-26-2013 10:59 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Odd brake pedal feel, fade? yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 09-11-2012 12:29 PM
Parking/Emergency Brake - "Clunk" EsoBOFH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-24-2012 11:43 AM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
