when installing coilovers, front should be lower than rear?
Hi Guys!
I'm about to install my new coilovers, Tein Flex A for my 2018 BRZ PP Tein official website suggests that recommended drop is -1.4 inch for front and -1.2 inch for rear. So I guess front should be lower that rear? Can you guys please give your opinion on this? |
Drives: 2014 GT86
My opinion is to not lower below 1". Or if you absolutely must, buy&install also roll center adjustment kit for front & diff riser for rear.
Also on tein's site for 2017+ USA BRZ Flex A i see recommended height not one fixed setting, but ranges, -1.8 to -1 range recommended for front, -1.6 to -0.8 recommended for rear. |
#3 | |
Also, do you recommend to lower front and rear at the same height? |
Anti stance.
It should be what it needs to be for the application.
Drives: Crapcan
I have run it both even and with some rake. I prefer with a little bit of rake, feels like it turns in better.
Weight Weenie
Drives: 15 FR-S
If doing Coilovers I would get it corner balanced too. It would be ideal to have it balanced front/rear and side to side
Drives: '13 Scion FR-S & '17 Toyota 86
Out of the box, the TEIN Flex A's on the 2018 BRZ should already be set to a 1.4-inch drop up front and a 1.2-inch drop in the rear.
Here is what they look like installed on my FRS: https://www.ft86club.com/forums/show...8&postcount=48 -Sam |
#10 | |
any intervention/crashing issue? |
#11 | |
Drives: 2014 GT86
First - to not fsck up suspension geometry, or if you do, fix it back (hence mentioned roll center adjustment kit), second - to reduce CV joint extra wear due too big angle and quicker failures (hence diff riser) Rake is just one of suspension setting, that works with all rest. In this case, when coilover manufacturer that designed them recommends such, i'd probably would go with that if know nothing better or have data/experience of other setting working better for me. Still, rake doesn't mean that you also need to overlower (both front & rear). Just that front is a bit lower then rear in this case. If manufacturer reccomended ranges included -1" front & -0.8" rear, i'd probably would go with that, unless you plan also buying/installing other mentioned parts to correct mentioned issues of lowering more. |
#12 |
Weight Weenie
Drives: 15 FR-S
#13 | |
Since Tein recommends -1.4inch front , -1.2 rear range, I will go -1.2 front , 1.0 rear! |
#14 |
Drives: 2014 GT86
Well, in url i found, it was, as i already posted in my first port in this thread:
"Also on tein's site for 2017+ USA BRZ Flex A i see recommended height not one fixed setting, but ranges, -1.8 to -1 range recommended for front, -1.6 to -0.8 recommended for rear." .. so i'd rather go -1" front and -0.8" rear then |
| Help installing dash cam (front and rear) | wild03 | Electronics | Audio | NAV | Infotainment | 10 | 09-08-2018 11:08 PM |
| Lower front more than the rear on coilovers? | stlgrym3 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 06-01-2018 02:21 AM |
| FS: Rear upper and lower arms, BC Racing Coilovers | Drull | Brakes, Suspension, Chassis | 38 | 02-23-2018 04:15 PM |
| Rear Suspension Sitting Lower Than Front. | Zeuseidon | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 38 | 12-06-2016 06:20 PM |
| BC coilovers, Hawk Pads, SPC rear lower control arms, P&L brake lines | twincamRob | Brakes, Suspension, Chassis | 10 | 12-28-2013 10:03 AM |
