Drives: Silver 2017 Limited with PP
Help installing dash cam (front and rear)
I would like to install a dash cam (Amazon has a cheap $20 cam with front and rear recording
https://www.amazon.com/Sebikam-Dashb...70_&dpSrc=srch Coupon code "SEBIKAMUSA" knocks that to $19.55. Plus, free shipping IS there a guide on what the best routing is and how to remove the panels on the BRZ? Thanks in advance. |
Sporadic Member
Drives: 2016 Halo FR-S M/T
Refer to this guide on how to install the front dashcam.
When I did my rear dashcam install, I followed part of the sharkfin antenna guide for removing the roof liner. |
| The Following User Says Thank You to KR-S For This Useful Post: | wild03 (09-06-2018) |
Drives: RAVEN FRS
The front is fairly easy just route the cable from the headliner to the passenger pillar then to the glove box. For my rear cam, I loosened the panel with the logo, there's like 5 or so bolts, fished the wire beside the trunk key hole.
| The Following User Says Thank You to darko For This Useful Post: | wild03 (09-06-2018) |
Drives: 2017 BRZ
No need to do more than the above noted headliner removal (and it doesn't even have to come off) for the rear camera, usually. I have previously run dual singles (remote base) and now a Street Guardian SG9663DC; in both cases cable went up the a-pillar for power, and across the roof along one edge. Quite simple. Both cameras mounted at the top of the front/rear windows.
| The Following User Says Thank You to cjd For This Useful Post: | wild03 (09-06-2018) |
Smiling
Drives: BRZ 2018
For the rear, i routed it through the pillars then through the rubber of the door thrn to the floor "scuff guard" and so on. Just follow the panels until you reach the back
No need to fully route it through the head liner. Done it this way for 3 different cars Sent from my iPhone using Tapatalk
| The Following User Says Thank You to Muchikori For This Useful Post: | wild03 (09-06-2018) |
#6 | |
Drives: 2014 Scion FR-S
I’ve also installed a front dash cam, you don’t have to remove panels, you just have to hide the wire along the head liner, and plug it into the outlet in your glove compartment. That’s the best way I’ve found to install and wire. Hope this helps. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Twitchy313 For This Useful Post: | wild03 (09-06-2018) |
A.K.A. Starlord
Drives: 2015 Series.Blue
Check out my blog post. Feel free to ask any other questions
![]() http://www.seriesblueadventures.com/...f770-dash-cam/
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. Last edited by Stang70Fastback; 09-06-2018 at 09:11 PM. |
Drives: 2016 Halo FRS
I installed my cam by tucking the wire under the headline, then under the plastic A pillar cover, then under the window weather stripping. There is a panel that can be removed so the wires can feed directly into the glove box all leading to a super stealth install.
| The Following User Says Thank You to jordan7831 For This Useful Post: | wild03 (09-06-2018) |
#9 | |
#10 |
Viafo A119 is pretty solid. It's a good balance of quality and cost. But any dashcam is better than no dashcam!
#11 |
Drives: Car Collector
Constant power from Dome light
I wanted to utilize my cameras parking mode and keep the glove box outlet free for other uses. I used a hardwire kit and came off of my dome light wiring which has constant power. Very easy to pull the dome light assembly down. My car sits garaged 98% of the time so I just pull the camera which has a quick disconnect bracket to not worry of draining the battery. I do not know if newer models have constant power at their dome lights or not though.
| Need help installing rear springs! | flashburn | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 03-29-2014 04:51 PM |
| Crap lights on my dash after installing coilovers. | Eelusive | BRZ First-Gen (2012+) — General Topics | 43 | 02-12-2014 01:08 PM |
| Dash blinker stay on after installing leds | Fr-Sheila | Issues | Warranty | Recalls / TSB | 14 | 02-05-2014 02:48 PM |
| Door Unlocked dash light coming and going after installing subwoofer | tbertran | Electronics | Audio | NAV | Infotainment | 0 | 01-01-2014 10:22 PM |
| DIY Thread on Installing a Front Lip ? Particularly the Downforce CF Front Lip | ScionFR-S | DIY (Do-It-Yourself) Guides | 10 | 12-22-2013 08:22 PM |
