Old 05-31-2018, 11:18 AM   #1
stlgrym3
Drives: 2017 Subaru BRZ Limited
Lower front more than the rear on coilovers?
When I got my Apexi coilovers I lowered about 1.5 inches front and rear. However, because of the higher wheel arch up front the wheel gaps in the front are quite large compare to the rear, I’m on 17” wheels by the way. Is it okay to lower the front even more to even out the wheel gaps between front and rear? Wouldn’t the car be slanted if I do that? Is it common practice to lower front more than rear?
stlgrym3 is offline   Reply With Quote
Old 05-31-2018, 11:29 AM   #2
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Something is wrong if you're seeing a big difference front-to-rear. There shouldn't be a big discrepancy if it was evenly lowered.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 05-31-2018, 11:33 AM   #3
stlgrym3
What I meant was the front vs rear wheel gaps visually. Don’t the front wheel arch higher than the rear begin with?
Old 05-31-2018, 11:38 AM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The difference is only supposed to be about an 1/8th inch. I would double check your install.
Stock Ride Height
Old 05-31-2018, 11:45 AM   #5
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
If you get the front and rear even at the pinch welds, the rear wheel arch should measure 1/8" lower than the fronts. It sounds weird but it's just the way they're designed on this car. I guess if you wanted them to look dead even then you'd actually need a 1/8" rake measuring at the pinch welds. Keep in mind fuel level and trunk junk can make a difference on this to.
smg1138 is offline   Reply With Quote
The Following User Says Thank You to smg1138 For This Useful Post:
wparsons (05-31-2018)
Old 05-31-2018, 02:49 PM   #6
wparsons
wparsons's Avatar
^^ What those two said. The difference at stock height is 1/8" (3mm), which you won't see without carefully measuring. I personally set my V3's to be even all around when measured fender to ground, so technically mine is lowered an additional 3mm up front.
flickr
Old 05-31-2018, 03:15 PM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
I wonder how lowering more front will affect weight distribution, downforce/lift bias, handling. Or that small of difference shouldn't be noticeable?
Old 05-31-2018, 03:28 PM   #8
stlgrym3
I think we r talking about different things. I was referring to the wheel gaps between the front and rear wheel arch. By default front wheel arch always appears higher than the rear, so when lowering both sides evenly, the wheel gap difference is still there.
Old 05-31-2018, 06:46 PM   #9
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I have Tein Flex A Coilovers installed recently, I have the opposite problem. My front is lower than the rear. But according to the people who installed it, it's set to "Tein Factory Recommendations". My front camber is roughly -1.5 and rear camber is roughly -2 degree.
N1rve
Old 05-31-2018, 08:00 PM   #10
Gunman
Drives: 2019 Mazda Miata RF
I'm pretty sure the car was designed with a bit of rake.
Gunman is offline   Reply With Quote
Old 05-31-2018, 10:02 PM   #11
norcalpb
norcalpb's Avatar
Yes to allow for max travel without hitting the shock against the CV joint.
Also max downforce yo
Old 06-01-2018, 03:03 AM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
In a bolt on street car that gets tracked, I'd say not that much. My lock rings backed off on my ride height adjustment and I was 16mm on the right front, and 12mm lower on the left front then the rear. I noticed the car was a little skittish over a crest under power, otherwise I didn't notice much else besides a little more rubbing then normal. I just reset it to where I previously was which is about 6-7mm lower in the front then rear. I guess potentially you can improve the effect of a rear diffuser with some positive rake. I doubt it is that much in a street car though.
Old 06-01-2018, 03:21 AM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
For improving rear diffuser angle/effect i guess car needs to be much lower and with side skirts to lessen air getting in from sides under body. So yes, at stock height probably downforce will not be changed much.
FS: Rear upper and lower arms, BC Racing Coilovers Drull Brakes, Suspension, Chassis 38 02-23-2018 05:15 PM
Rear Suspension Sitting Lower Than Front. Zeuseidon Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 12-06-2016 07:20 PM
FS: KW V3 Coilovers, HKS Front Pipe, Spc Rear Toe arms with Spl Lockout kit Kaos989 Canada Classifieds 10 09-16-2016 02:55 PM
Front and Rear Camber kit /w Coilovers slow n FuRiouS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-07-2016 07:59 PM
BC coilovers, Hawk Pads, SPC rear lower control arms, P&L brake lines twincamRob Brakes, Suspension, Chassis 10 12-28-2013 11:03 AM
