Old 04-22-2018, 01:35 PM   #1
Flame9020
Drives: 2015 Scion FR-S
Loud Clunk while driving
I just took my car out for a drive and it stated to give out a large clunk after I went over a small bump. It now does it while speeding up, slowing down, going over bumps, and did it when it got out of my vehicle. The sound is coming from the rear passenger side of the car.
Car is a 2015 with 33k and completely stock. Are there just some bolts in the suspension that might have come loose or am I possibly looking at a major repair?
Flame9020 is offline   Reply With Quote
Old 04-22-2018, 02:54 PM   #2
norcalpb
norcalpb's Avatar
Check the rear top strut nut, and make sure you have an Allen wrench in the top of the strut so you don’t spin the shaft.
I would also make sure the rear endlinks are tight, but these aren’t as known to make noise as the front endlinks.
Old 04-22-2018, 05:00 PM   #3
FirstWinter
Drives: Car
If it's a completely stock car with no record of accident or touching any parts recently I would look for other causes of noise besides suspension components first. Do you have anything loose in the trunk/cabin possibly? A video recording of it would be nice to help identify the cause.
If you have eliminated those possible causes then I would proceed to examine suspension components and take peek under the car for any suspects. Check lug nuts, brake caliper, coilover strut, etc.
FirstWinter is offline   Reply With Quote
The Following User Says Thank You to FirstWinter For This Useful Post:
humfrz (04-22-2018)
Old 04-22-2018, 10:41 PM   #4
Flame9020
[ame="https://www.youtube.com/watch?v=5eOKpn1r5Uc"]BRZ Clunk - YouTube[/ame]
This video is a perfect representation of the sound. The video is of the sound coming from the front of the car rather than the rear like mine. The car is currently sitting in a maintenance shops lot so I can't get a video atm. I checked the lug nuts and they were still all torqued to spec and when I jacked up the car I didn't see anything abnormal. My car knowledge is extremely limited so that isn't saying much.
I checked the trunk and everything seemed to be okay there. I read in other places that it could be the jack moving around but the noise was still there even after I removed all the foam padding in the trunk.
Old 04-23-2018, 12:47 PM   #5
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I had to get my front strut bushings replaced around 15K miles, 100% stock. Slightly different sounds, since it first showed up when turning the wheel at low speed and the bushing would bind up and then release. But if they were far enough gone, they could certainly make the same noise going over the right kind of bump. Regardless, you have something loose and it needs to be investigated, so a trip to a reputable shop is advisable if you don't have the ability/experience yourself.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 04-23-2018, 08:21 PM   #6
Flame9020
Got a call back from the shop. Apparently my right rear strut is destroyed and my left is about to go. Thank you Indiana potholes...
Old 04-23-2018, 09:28 PM   #7
norcalpb
norcalpb's Avatar
Time for some 2017/18 Sachs suspension
perrin catback resonated - loud enough or too loud? theflathead Engine, Exhaust, Transmission 33 01-22-2018 05:46 PM
Loud clunk from rear of car tennisfreak Issues | Warranty | Recalls / TSB 14 11-26-2014 12:55 PM
Loud clunk noise when i pull E-Brake Deagle50 Issues | Warranty | Recalls / TSB 28 09-20-2014 01:01 AM
Loud thud from inside car when driving over things? Weeber Scion FR-S / Toyota 86 GT86 General Forum 21 10-15-2013 02:04 AM
Loud pop/clunk under braking. Panda Grahams Issues | Warranty | Recalls / TSB 2 07-26-2013 03:13 PM
