Drives: '14
Recommended gauges for supercharger
Hey yall,
I'll be going boosted with the Sprintex 210 non-IC soon on an auto tranny. What gauges should I pick use? Is it absolutely necessary for them? I won't be driving hard or racing. |
Drives: brz 2017 hksv2
good practice for FI is to tune with a wideband
so you could buy a AEM wideband that requires its gauge always connected so that s one oil pressure sensor and gauge also good to have and keep visible (gauge or torque/dash command or ecutek ecu connect) oil temp |
Drives: 2017 toyota 86
Just get a scangauge. All you need you have a sprintex. You don’t need Oil pressure gauge since your not tracking. Sprintex doesn’t need wideband no point really stock 02 is already pretty much a wideband. Scangauge is cheap, quick and easy to install, and can monitor 4 things at once. AFR, boost, oil temp, transmission temp, coolant temp, intake temp, all 4 tire pressures and about dozen other things. Just pick your favorite 4. Don’t need anything fancy unless your making loads of boost and tracking your car.
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | jflogerzi (06-25-2019) |
I use my phone since I have the ecutek Bluetooth kit. I create different dashboards for different driving situations. But it's free if you have a modern smartphone and a 10$ phone mount. I have my phone always plugged in due to use Android Auto. Works and it's free.
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | kev0 (06-26-2019) |
#5 | |
Drives: '14
#6 | |
Oil and coolant temps AFR both command and actually Short term and long term fuel trims IAM Knock correction Sent from my GM1915 using Tapatalk
If you want to monitor knock, knock correction is not enough, you need to log also Ignition correction Ap fine
| The Following User Says Thank You to tomm.brz For This Useful Post: | jflogerzi (06-26-2019) |
Logging yes, monitoring not so much. A knock event will happen so fast your not going to see it unless your staring at the screen at that exact moment. Just monitor IAM is enough. Log everything to dial in tune. Then IAM AFRs and temps to make sure everything is still going smooth.
i have ecu onnect in my Xtrons since 7 months and see every little knock that occurs in my car, dont know what you are talking about
i set red colour when they move from 0 so i see even with the tail of my eyes immediatelyyou could even set the screen flashing for even a little -0.4 correction if d like but if you think you can not see correction i just guess you dont have ecu connect in your radio or even never set it up depending on how the tune is setup, or on oarticular situation, you can have corrections as high as -4 and not have AM moving from 1.0 |
#10 | |
Admittedly I haven’t used what your using. But scangauge, ecutek both laptop and phone Bluetooth, OFT, and dash command phone app. If it has a 10hz refresh and a knock event lasting 1/10th of a second happens you blink and it’ll be off the screen. Datalog is obviously different. If a knock event worth seeing happens it’ll drop your IAM if your tune is setup correctly. |
#11 |
i have seen multiple logs from fensport and delicious tuning kicking a -3 correction and not moving AM, it s more on repetitive knocks that triggers am, or on particular zones depeding how it is set the Knock corr A table
anyway i do not stare at my screen, but i always see if a correction happens and i often keep a ignition timing slider there as I sometimes use Boostane and it makes miracles with a supercharger, and advance timing on the fly until a correction occurs
| recommended places to buy a supercharger and install? | Phosho510 | Northern California | 17 | 11-27-2016 06:28 PM |
| Tire Pressure and Temperature Gauges recommended for track use | Toyarzee | Tracking / Autocross / HPDE / Drifting | 16 | 01-26-2016 08:23 PM |
| Gauges for supercharger | BRZUK | Forced Induction | 18 | 01-22-2015 06:12 PM |
| Necessary gauges | misooscar | Engine, Exhaust, Transmission | 5 | 09-18-2014 02:42 AM |
| Gauges for supercharger? | LtS720 | Forced Induction | 15 | 12-23-2013 09:14 PM |
