Drives: 17 BRZ PP CWP
Torque App AFR 5.XX:1 lower than OFT
While car is idling if I switch from Torque to OFT the Torque app reads the AFR as 9.XX:1 (Mesured) and the Open Flash Tablet reads 14.XX:1. Even taking a drive with one then the other the Torque app always reads 5 lower than it should. On deceleration I get 20.0 on OFT and 15.0 on Torque. Anyone have insight as to why this might be happening? Maybe I need a PID for 2017 model? All other readouts seem to be correct even oil temp which I was told I would need a PID for.
Drives: GT86 2013
The ECU is providing lambda (1.00). It's the client (OFT, Torque app, etc) that multiplies the lambda value with 14.7 to get the (calculated) AFR.
Maybe Torque think you are using E85? That would give you a AFR of 9.765 for lambda 1.00. |
I am running E85. Anyway to correct it on the torque app? Just so when I glance over my brain doesn't have to translate it every time.
Drives: GT86 2013
I don't know. Maybe you could try changing fuel type in the Torque vehicle profile from E85 to Petrol?
#5 | |
Even if your on e85 leave the torque app in petrol mode. Everything the ecu does or calculates is referenced back to petrol afr even when your on e85. The 02 measures lambda but the ecu converts it vack to petrol afr amd all the tavles are referenced back to petrol afr even if your on e85. Lambda 1 iss 14.7 petrol afr and 9.8 fir e85 if its 85% ethanol. This will change as athanol %changes. Its easier to do what the ecu does and jyst use petrol afr. Oft tune idle afr petrol or e85 jyst look for 14.7 Full throttle should go down to about 11.8 petrol and 12.2 e85 as the e85 tunes target a skightly leaner afr than the petrol tunes |
Thanks for this, I was thinking it seemed a little high on WOT and it is good to know I can use this reliably as a way to know if I get some bad E85 without constantly plugging in the OFT.
| Calculate torque when using a crows foot on torque wrench | BirdTRD | DIY (Do-It-Yourself) Guides | 0 | 10-11-2015 04:02 PM |
| Requested torque and Calculated torque | nickw14 | Software Tuning | 3 | 06-13-2015 04:09 AM |
| How to fix the torque dip. | Manji | Engine, Exhaust, Transmission | 15 | 01-24-2015 03:45 PM |
| Torque Pro App | poorsche | Engine, Exhaust, Transmission | 4 | 12-12-2014 05:01 AM |
| 2.5L with lower revs/more torque, or 2.0L with higher revs? | Superhatch | Engine, Exhaust, Transmission | 124 | 08-28-2013 12:20 PM |
