Old 06-05-2019, 10:30 AM   #1
8inchAzN
Drives: Car
Clutch Engagement
My 17 BRZ has about 70k kms on it now and it feels like the clutch engagement point has gotten a lot higher since the car had 7 kms on it.
Has anyone else noticed this on their vehicles? I read a couple of comments from earlier threads that the engagement point in these cars don't change over the course of the car's life. To me I am certain that the grab point has changed.
8inchAzN is offline   Reply With Quote
Old 06-05-2019, 10:41 AM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
1. As your clutch wears down, there is physically more space between the pressure plate and friction material. This will increase pedal travel.
2. Check clutch fluid level, just for fun.
3. You can always adjust the clutch grab point whenever you want. http://www.ft86club.com/forums/showthread.php?t=8040
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
naor223 (06-06-2019)
Old 06-05-2019, 01:19 PM   #3
humfrz
Do you REALLY think that a 0.00000000001 mm, is going to make any significant difference in the clutch travel distance?
@Ultramaroon says that is
I don't want to get in the middle of this -
humfrz
Old 06-05-2019, 02:01 PM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
humfrz
I've owned five manual cars and on all of them, over time, the clutch pedal travel has increased while the grab point has gone higher. It might not be entirely because of the clutch disk getting worn out, but it contributes. What other explanation is there, other than more space between the disk and PP?
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
8inchAzN (06-05-2019), humfrz (06-05-2019)
Old 06-05-2019, 02:06 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Yet you inject yourself into the thread and summon me.
Are you bored?
Guys, the clutch mechanism floats just like the pots in your brake calipers. It's a simpler version of the same mechanism. The engagement profile may change as the disk wears but, other than seasoning to taste, there's no reason to adjust the pedal throw.
That being said, I loathe the stock setup. I seasoned mine heavily.
soundman98 (06-05-2019), Sportsguy83 (06-05-2019)
Old 06-05-2019, 02:40 PM   #6
humfrz
Hell, don't argue with me . I believe what I do because ol @Ultramaroon told me so - so, go argue with him -
humfrz
Sportsguy83 (06-05-2019), Ultramaroon (06-05-2019)
Old 06-05-2019, 02:45 PM   #7
humfrz
Are you bored?
NO, I am NOT bored! I'm just hungry and it's almost nap time -
humfrz
jcw99 (06-05-2019), Ultramaroon (06-05-2019)
Clutch Engagement Improved! enjoyminutemaid Engine, Exhaust, Transmission 53 11-07-2018 06:31 PM
clutch Engagement Issue? Bu-Tang Issues | Warranty | Recalls / TSB 68 02-19-2017 02:03 PM
Hot/cold clutch engagement issue Trust86 Issues | Warranty | Recalls / TSB 0 01-19-2017 08:40 AM
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Jerky clutch engagement Namuna Engine, Exhaust, Transmission 11 03-14-2014 05:21 PM
