Old 05-29-2019, 05:05 PM   #1
Turbo
Drives: FR-S Turbo
When to use a higher pressure rad cap?
I've noticed that some of the aftermarket rads (like the Jackson Racing) even come with them.
Can I run an upgraded cap with the OEM rad safely?
Turbo is offline   Reply With Quote
Old 05-29-2019, 05:07 PM   #2
15limited
15limited's Avatar
A cap ain't gunna make ya or break ya.
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 05-29-2019, 06:44 PM   #3
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I've been using a higher pressure radiator cap for over a year now. You won't notice a difference except now when your coolant hits 250f you'll know it's not boiling.
Trueweltall is offline   Reply With Quote
Old 05-31-2019, 10:27 AM   #4
Icecreamtruk
Drives: Track preped NA FRS
When your headgasket is dying but you want to keep tracking. Wish I was joking but I ended up "patching up" the problem to finish the season and rebuilt later. It worked, until it got worse.
Old 05-31-2019, 12:13 PM   #5
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
A lower temp thermostat is more useful than a higher pressure radiator cap.
Old 05-31-2019, 12:29 PM   #6
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
Honestly, I'd advise against running a higher pressure radiator cap unless you've upgraded all the components which would see pressure to a point where they're rated to take the pressure you want to set and then some for safety. This is basically what I did. After swapping my radiator, I also swapped out the hoses and the filler neck before switching to a higher pressure cap.
Tristor is offline   Reply With Quote
Old 05-31-2019, 01:00 PM   #7
JD001
JD001's Avatar
Drives: Subaru BRZ
Did you use a raw egg to fix the problem temporarily?
Old 05-31-2019, 02:04 PM   #8
Icecreamtruk
lol no, but if there's any interesting stories about it...
Old 05-31-2019, 02:19 PM   #9
JD001
JD001's Avatar
Drives: Subaru BRZ
I think ole @humfrz may have some 'back in the day' stories about using eggs to fix cars.. or should that read carts??
Old 05-31-2019, 02:38 PM   #10
Trueweltall
This won't be an issue.
Old 05-31-2019, 02:47 PM   #11
humfrz
Well, I preferred to eat the egg and use raw oatmeal to put in the radiator to fix a small leak. If a radiator hose had split, duck tape it up and don't put the radiator cap back on.
hints by Bubba
Old 05-31-2019, 06:23 PM   #12
Tristor
Tristor's Avatar
So when you say "this won't be an issue", by implication I'm taking it that you're saying the factory radiator with plastic end tanks known for cracking over time due to heat cycling, and the hoses and plastic filler neck engineered specifically for the rated pressure of the cooling system won't be harmed or experience accelerated wear in any way by changing the pressure relief valve to open at a higher pressure?
Or maybe, just because people don't immediately see their cars blow up doesn't mean something is a good idea and totally harmless. Pressure systems are serious business. It's not significantly costly to upgrade the related components to handle higher pressures if you have a reason to do so. For the vast majority of people running a higher pressure cooling system is completely pointless and buying a higher pressure radiator cap is a waste of money.
Old 06-01-2019, 12:08 PM   #13
Trueweltall
You're overthinking it Tristor.
Old 06-01-2019, 12:22 PM   #14
15limited
15limited's Avatar
U mad cuz u got roasted
Resale higher than expected? Dr Speed Scion FR-S / Toyota 86 GT86 General Forum 22 11-11-2015 02:43 PM
BRZ has a higher perceived value ? irax BRZ First-Gen (2012+) — General Topics 27 01-09-2015 12:20 PM
higher Boost? Scalzo Forced Induction 19 09-10-2014 05:20 PM
Anyone know where to get higher than 91 octane? 86main Northwest 37 03-01-2014 03:05 PM
Where can i get fuel higher than 91? XPR Small Block Northern California 22 03-24-2013 09:56 AM
