Old 05-28-2019, 12:57 AM   #1
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
Creaky/poppy suspension or steering components?
About a month ago, I started hearing my suspension creaking/popping at various time. Mostly very low speed bumps and also while turning the wheel at no or low speeds.
I thought it may be the sway bar end links, so I tightened those to make sure they weren't slipping. I still hear the same sounds.
I actually made a video for it as well.
So far my suspension mods are:
CSG Spec Tein Flex A's
Verus Rear Lower Control Arms
Whiteline front and rear sway bars
Whiteline front end links
SPL rear end links (whiteline ones pulled out threads)
So nothing too crazy.
My thoughts have now shifted to the steering rack, but I'm leaning on you guys that may have experienced this to let me know your own.
[ame="https://www.youtube.com/watch?v=PS-NvFkVWrg"]Here's the vid.[/ame]
Hopefully the sounds are loud enough for anyone to hear.
Thanks for all the help in advance!
Rybot is offline   Reply With Quote
Old 05-28-2019, 01:29 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I would check sway bar end links first.
Old 05-28-2019, 08:42 AM   #3
Rybot
Rybot's Avatar
I had already checked my end links first, my man.
Thoughts on it being anything else?
Sent from my Pixel 2 XL using Tapatalk
Old 05-28-2019, 09:25 AM   #4
ermax
ermax's Avatar
Overpipe hitting something?
Old 05-28-2019, 09:28 AM   #5
Rybot
Rybot's Avatar
Nah. I've never had exhaust clearance issues in the 4 years I've had my exhaust (minus driveshaft area with a single piece shaft).
Old 05-28-2019, 09:34 AM   #6
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
I had a set of Tein Flex Z and the nut at the top of the strut loosened itself. Try checking that.
BigTuna is offline   Reply With Quote
Old 05-28-2019, 09:56 AM   #7
ermax
ermax's Avatar
The EPS on this car has a rubber coupler between the EPS motor and the worm gear. With time this coupler will crumble and then you have metal to metal contact and it makes a bunch of noise at low speed. The sound in your video sounds nothing like the EPS issue but you may want to focus some attention to the EPS unit to rule that out. The EPS is connected directly to the steering column down around the pedals. If the sound seems to be coming from there then that could be your issue. It’s a $7 part and not too difficult to install.
Old 05-28-2019, 10:19 AM   #8
Rybot
Rybot's Avatar
Were you getting any noise from it once it had loosened?
Old 05-28-2019, 10:23 AM   #9
Rybot
Rybot's Avatar
I appreciate the info here.
I haven't noticed the noise bear the pedals. It's definitely a popping sound originating near the wheel wells.
That said, I do need to lube the steering column bushing in the firewall, so while I'm in there, I'll check out the coupler, unless that's what you're describing.
Old 05-28-2019, 10:29 AM   #10
BigTuna
BigTuna's Avatar
Yep. I couldn't find it under the car no matter how hard I looked. I had the hood open and happened to notice one had less threads sticking out of the nut and could spin it by hand. Tightened it to 44ft-lbs and no more noise.
Old 05-28-2019, 10:34 AM   #11
Rybot
Rybot's Avatar
I'll give that a shot then!
I'll admit that's one connection I didn't readily think to tighten.
Old 05-28-2019, 01:56 PM   #12
ermax
ermax's Avatar
You can’t just glance at the coupler. It’s inside the EPS unit. You have to pull a few interior panels off and then unbolt the column so you can drop it and then access the EPS unit. You then unbolt the EPS motor which exposes the coupler. But I seriously doubt that is your problem based on the sound in your video.
Old 05-28-2019, 02:05 PM   #13
Rybot
Rybot's Avatar
Alright. I'll leave it for another day then.
Thanks!
Old 05-28-2019, 02:07 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
My Bad
I'd check the preload collars on the coil overs too. They like to work loose, especially the fronts. I have to check mine fairly regularly.
Groan and Creaky Front Suspension??? jadewbj Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 10-11-2019 02:19 PM
WTB: OEM suspension components Agent_D Want-To-Buy Requests 0 03-20-2018 06:31 PM
FS: AVO suspension components Avo1789 Brakes, Suspension, Chassis 7 01-15-2016 07:25 AM
Rear Suspension Components jgardner Want-To-Buy Requests 4 07-28-2014 11:55 PM
Koni Suspension Components dale.m Suspension | Chassis | Brakes -- Sponsored by 949 Racing 76 06-20-2013 10:00 PM
