Old 08-30-2017, 09:56 AM   #1
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
Groan and Creaky Front Suspension???
First things first mods:
Tein Flex Z dampers (recently installed to replace a set that had 50k on them)
Whiteline Sway Bar with adjustable end links (45k since installed)
Whiteline Steering Rack Bushings (45k since installed)
A little while ago I noticed a groan/creaky noise in the front suspension when the car is stopped and you turn the wheel to the right and left. You also hear this creak/groan noise and you go over bumps in the road.
I thought it might have been the coils needing a rebuild so I sent my old set out to be rebuilt and got a new set and threw them in. It changed nothing.
The noise goes away totally if the car sits for a few days (don't really drive it on the weekends that much) for about 30-40 minutes until I think it loosens up.
I thought originally it may be the steering bushings but the fact it happens over bumps also not just when turning makes me think that it is less likely that.
I am wondering if it is maybe the bushings in the control arms or maybe a combination of both?
Any ideas?
jadewbj is offline   Reply With Quote
Old 08-30-2017, 11:16 AM   #2
BRZHarley
Drives: 69 Firebird, 2015 BRZ
My first suspect would be the white line swaybar bushings... just pulled mine after 10k miles to clean and because they were groaning and squeaking... Thay maybe listed as greaseless but lube them with a good bearing grease and see what happens..
Ed
BRZHarley is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZHarley For This Useful Post:
DarkPira7e (10-02-2019), Teseo (08-30-2017)
Old 08-30-2017, 11:28 AM   #3
Somerandom18
Drives: 2017 manual BRZ
Apply grease to bushings and report back.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 08-30-2017, 12:52 PM   #4
jadewbj
jadewbj's Avatar
Will do, I am very suspect of the sway bar bushing too.
What kind of grease should I use?
Old 10-02-2019, 01:22 AM   #5
DaveFTW
DaveFTW's Avatar
Drives: 2013 86
did you ever get this issue figured out? i'm having a similar problem.
I'd change the world if I could change my mind
DaveFTW is offline   Reply With Quote
Old 10-02-2019, 08:21 AM   #6
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Check for cracks in the top hats too.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 10-02-2019, 05:22 PM   #7
norcalpb
norcalpb's Avatar
Does it make the noise when you turn the wheel at low speeds?
Old 10-11-2019, 10:09 AM   #8
Scoob
Scoob's Avatar
Drives: 2013 FR-S Asphalt
I had this same issue that had gotten progressively worse throughout this year (~40k miles on the clock). After tightening and banging on everything in the suspension, swapping out my coil-overs for OEM set up, I figured out that it's the steering. I've found two problems - the knuckle joint before the steering rack needs lubrication and the steering rack itself seems to be loose!
I've sprayed WD-40 onto the knuckle and the creaking went away (mostly). I still need to get up there to tighten the rack itself which is rattling over small bumps in the road, etc.
2013 FR-S Asphalt Grey
HKS Hipermax IV GT
Sparco Assetto Gara MGC 17x7.5
Invidia N1 exhaust
Scoob is offline   Reply With Quote
Old 10-11-2019, 10:37 AM   #9
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
You should look at replacing your steering rack bushings if your rack is making most of the noise. Very important though, WD-40 is not really a lubricant, it's a solvent. If you need to lubricate something you should be using a quality grease or fluid film, not WD-40. WD-40 will end up dissolving and removing what little grease may have remained from the factory originally and can actually end up making the problem worse (or worse yet causing parts to seize). Never use WD-40 as a lubricant.
Tristor is offline   Reply With Quote
Old 10-11-2019, 01:19 PM   #10
Scoob
Scoob's Avatar
Gotcha on the SR bushings. Hopefully, it's just loose and not dying as some other folks have experienced.
The WD-40 was just a test to see if anything on the knuckle would help with the noise. It did which tells me that it needs to be relubed with something appropriate to keep the noise away. I'm waiting to do all of that together (to give the WD-40 a chance to go away).
HKS Hipermax IV GT
Invidia N1 exhaust
Clutch squeak, grind, groan TSB released. Kicker18 Issues | Warranty | Recalls / TSB 153 10-01-2019 12:50 AM
WTB front suspension arms Whitel Want-To-Buy Requests 0 11-28-2016 11:39 AM
FS: ST Suspension Front Swaybar bombardius Brakes, Suspension, Chassis 2 04-16-2016 10:50 AM
Front Suspension 'discovery'? Dimman BRZ First-Gen (2012+) — General Topics 13 07-23-2011 08:22 PM
