Old 05-22-2019, 09:50 AM   #1
stayclam
Drives: Acura
Need new rotors - advice on correct parts
Hello,
It's about time to replace the rotors & pads in my '13 FR-S w/ 65K miles. I don't track my car, but do some spirited street driving.
I decided to go w/ Akebono ProAct pads (ACT1539 & ACT1124). For the rotors, I've browsed many sites (including TireRack, CarID, AutoAnything) and am left confused on the correct size. Some sites show 292 mm discs while others show 277 mm discs (or both).
I'm considering Centric Plain rotors, but can someone confirm the correct part numbers?
Front: 120.47021
Rear: 120.47031 or 120.47029?
Thanks.
stayclam is offline   Reply With Quote
Old 05-22-2019, 10:31 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
In different countries, different brake sizes were offered.
https://www.ft86club.com/forums/showthread.php?t=123804
This may shed some light on it, there are a few threads on the subject. I'd purchase the rotors from an aftermarket parts store that knows its market and won't list the wrong sizes. Counterspace Garage, FT86Speedfactory, 86speed, etc. They will offer the correct U.S spec sizes
Old 05-22-2019, 11:14 AM   #3
Racecomp Engineering
We generally use the correct size Centric premium rotors on our street cars. They're not listed on our website, but let me know if you want a set.
- Andrew
Old 05-22-2019, 11:33 AM   #4
jamal
jamal's Avatar
Drives: Legacy GT
As far as I know, none of these cars in the US/north america came with the small brakes.
So, yeah, 47031 rear.
The rear pads are also different part numbers between the two, but I think they will still interchange.
jamal is offline   Reply With Quote
Old 05-22-2019, 11:50 AM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Originally Posted by stayclam View Post
Hello,
Front: 120.47021
Thanks.
USDM Standard Caliper (Vented front and rear)
Front: 120.47021
Rear: 120.47031
I bought these myself some time ago from Rallisport Direct
Some European/Japanese market cars came with a solid rear rotor (unvented).
EndlessAzure is offline   Reply With Quote
Old 05-22-2019, 12:54 PM   #6
stayclam
Drives: Acura
Thank you, gentlemen! I'm good to go.
centric rotors, rotors
Correct size of OEM V belt for BRZ jslack Engine, Exhaust, Transmission 2 12-12-2018 03:28 PM
Correct aftermarket LED wiring? leevanf Cosmetic Modification (Interior/Exterior/Lighting) 5 09-28-2017 11:39 PM
Groves in front rotors (replacement advice) Whooosah Suspension | Chassis | Brakes -- Sponsored by 949 Racing 34 05-03-2016 08:40 PM
correct offset jonperezinsd Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 03-02-2016 02:20 PM
Correct oil filter for 86? 130 or 160/15A? kharn83 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 11-27-2013 01:28 AM
