Old 03-02-2016, 04:20 AM   #1
jonperezinsd
Drives: Subaru BRZ [San Diego 86 Club]
correct offset
Im in the process of getting some SSR formula mesh..18x9.5 but im not sure which offset i need to get.. I want to run flush.. i am current lowered on tein street flex coil overs.. thanks in advance for the help..
jonperezinsd is offline   Reply With Quote
Old 03-02-2016, 05:51 AM   #2
swarb
You asked the same question almost 3 years ago. I think you should do a search.
http://www.ft86club.com/forums/showthread.php?p=1048045
The Following User Says Thank You to swarb For This Useful Post:
go_a_way1 (03-02-2016)
Old 03-02-2016, 07:34 AM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Why you go change your avatar on me. I almost didn't know who you were anymore lol
And op he's right you know?
Old 03-02-2016, 11:42 AM   #4
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
Hey man, I can help you out.
If you have stock brakes and want to run Formula Mesh then you can run SL disk all the way around (lowest disk for biggest lip). The sizes that SSR offers are 18x9.5 +43 (67mm lip) / +30 (79mm lip) in SL disk. The +43 offset is safe. Can run a 265/35 with little camber and a roll and be flush. The +30 is harder to fit. Will have to stretch a 235 or 245 with camber and roll to be somewhat flush. But will still have a little poke.
Kami Speed is offline   Reply With Quote
Old 03-02-2016, 02:17 PM   #5
jonperezinsd
Thank you very much.. that is exactly the info I needed... now it's time to order..
Sent from my SAMSUNG-SM-N910A using Tapatalk
The Following User Says Thank You to jonperezinsd For This Useful Post:
Kami Speed (03-02-2016)
Old 03-02-2016, 02:20 PM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Order from @Kami Speed I would hope.....
The Following 3 Users Say Thank You to go_a_way1 For This Useful Post:
Kami Speed (03-02-2016), Leonardo (03-03-2016), swarb (03-02-2016)
BBS RS BBS RS 17x9 17x10 5x114 95BRZ Wheels and Tires 4 03-02-2016 03:57 PM
Searching for correct fitment Lischynski Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 05-17-2014 07:35 PM
Widebody correct fitment AtlasMick Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 01-20-2014 01:27 PM
Correct oil filter for 86? 130 or 160/15A? kharn83 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 11-27-2013 01:28 AM
correct idle rpm after warmup StormTrooper Issues | Warranty | Recalls / TSB 11 04-27-2013 07:00 PM
