Drives: 2014 BRZ Limited A/T
Correct aftermarket LED wiring?
Ok quick problem.. i already inserted it before double checking with the adapter and i didnt realize the adapter has a specific plug side only.. is it even possible to remove and switch these wires? Or is cutting them them and interchanging their stems the only option? Or.. can i cut the plastic piece at the center adapter?
Drives: Black 86 GTS
Yup follow the black.
Ok i just
Destroyed the middle plastic piece instead lol Sent from my iPhone using Tapatalk |
I just used an adapter cable
Sent from my computer using a keyboard |
You can remove the pins from the socket and swap them around if it isnt too late. If you look inside the connector you will see a tiny plastic tooth/tab that holds the pin down. You need to lift this and then pull the wire out from behind. Similar to the tail light connectors when you need to swap wires.
I have a video for the tail light connectors that might help understand. They basically all work like this. |
| Using factory wiring for aftermarket fog light kits | Wizardhat | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 12-05-2021 04:05 PM |
| Horn wiring for aftermarket wheel? | acpstunts | Electronics | Audio | NAV | Infotainment | 0 | 12-06-2016 11:52 AM |
| Rear View aftermarket wiring... help! | DV84 | Electronics | Audio | NAV | Infotainment | 0 | 07-27-2016 12:07 PM |
| 2016 Aftermarket HU - Stock Wiring | Luftwaffel | Electronics | Audio | NAV | Infotainment | 19 | 12-07-2015 04:44 PM |
| Aftermarket Headunit to Factory wiring harness? | Dadhawk | Electronics | Audio | NAV | Infotainment | 9 | 11-13-2015 11:23 AM |
