Old 05-18-2019, 08:36 PM   #1
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Who Uses Oil Scavenging Pump for Turbo Drain
I'm on the final steps of installing my turbo kit, and just realized that there's no way in hell I can properly drain the oil back into the pan. Does anyone use a scavenging pump to force feed the pan and keep the oil from back up?
Not talking about the AVO kit.
Old 05-18-2019, 09:47 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
IIRC the WRX uses a scavenge oil pump. Why try to reinvent the wheel when you can use and OEM designed off the shelf part? Just grab one from a Subaru dealer.
Old 05-18-2019, 09:57 PM   #3
DarkPira7e
DarkPira7e's Avatar
It does use one, but doesn't it bolt on to the turbo itself? I'll look into it. I had convinced myself I needed an inline pump
Old 05-19-2019, 02:23 PM   #4
solidsnake11
Drives: brz
I used the wrx scavenge pump to pump oil through the oil cooler. The internal return is jb welded and the new 6an is welded on the cover for oil cooler feed. You have to use an adaptor plate for our NA engines.
I could machine the adaptor plate but you would need to drill the three holes for the pump body, the red ones in picture and counter sink them on the back side, also you would have to set the depth of the drive. I used a three jaw puller and a c clamp to move back and forth. I also used a hammer to hit the top of puller and c clamp when it gets too much for them to move. This moves the gear on the shaft to set how far the drive sits in the cam. The plate has a lip to center the pump in the cylinder head that may need a light sanding to pull up tight and center the pump. I guess I could machine all the holes but I don't have a loose pump to test fit.
solidsnake11 is offline   Reply With Quote
The Following User Says Thank You to solidsnake11 For This Useful Post:
DarkPira7e (05-20-2019)
Old 05-19-2019, 04:32 PM   #5
solidsnake11
Drives: brz
I have also used a 12v holley gear fuel pump for the scavenge pump on a motorcycle. The turbo needs a sump chamber and mine needed to have a vent or the turbo would stop turning at an idle when the pump was on.
Old 05-19-2019, 11:52 PM   #6
DarkPira7e
DarkPira7e's Avatar
Seems like a ton of work! Pretty cool though! I ended up buying a TurboWerx pump today, I'll see what headaches that introduces. At least my oil drain won't be one of them.
Old 05-20-2019, 08:10 AM   #7
solidsnake11
Drives: brz
If your going to use it as a scavenge pump only, it doesn't need to be modified for the return
Old 05-21-2019, 03:00 AM   #8
Hags86
Drives: Toyota GTS 86
I found the TurboWerx is overpriced and poor quality. Failed after about three months and left me stranded on the highway (blowing huge plumes of smoke as the oil leaked past the seal into the exhaust).
Switched to a Marco pump and been very happy with it.
(The Coyoda kit supplies Marco but when I bought my they couldn't source the Marco one so supplied TurboWerx one. They swapped it out when it failed.)
2013 Toyota 86: 275rwkW
Coyoda Water-to-air Intercooled Turbo with GTX2863. CP Carillo Rods and Pistons. Motec M150 ECU. Motec C125 Dash. Holinger SG 6 Speed Sequential Gearbox. OS Giken LSD. MCA Reds Coilover. AP Racing Essex Sprint Front Brakes. PWR Radiator and Intercooler heat exchanger.
Hags86 is offline   Reply With Quote
The Following User Says Thank You to Hags86 For This Useful Post:
DarkPira7e (05-22-2019)
Old 05-22-2019, 07:01 PM   #9
DarkPira7e
DarkPira7e's Avatar
Haha oh no, don't tell me this. I guess I'll find out, it's supposed to be delivered tomorrow. I went with the "base" pump, not the Exo pump. I'll keep the Marco pump in my sights if this pump pulls anything funny.
Old 05-29-2019, 12:39 PM   #10
tom@ptuning
tom@ptuning's Avatar
Drives: 2013 Scion FRS
On our PTUNING turbo kit we use a mechanical scavenge pump
tom@ptuning is offline   Reply With Quote
Old 05-31-2019, 05:13 PM   #11
Hags86
Just keep a few spare fuses in your car. Might get you home in pinch.
AEM Fuel Pump DeltaEcho Engine, Exhaust, Bolt-Ons 48 06-21-2019 10:32 AM
Turbo and Walbro 485 Fuel Pump Eazy-V Forced Induction 17 07-17-2018 03:55 AM
FS: SBD Turbo Oil Pan with pre-welded return drain Taco Man in HD Engine, Exhaust, Bolt-Ons 3 06-01-2018 04:47 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
PTuning oil scavenging pump Dephective Forced Induction 7 05-08-2014 06:59 PM
