Old 05-15-2019, 02:25 AM   #1
AndehLu
Drives: 2015 Turbo Brz
2015 BRZ car starts then dies right away
[ame]https://www.youtube.com/watch?v=Fan0L7agrno[/ame]
Disregard the rattling noise in the video the car is boosted so its the sound from the piping.
The car is 2015 Subaru BRZ automatic transmission with 65,000 miles. Turbo as well with ultimate racing turbo kit. On pump gas (91).
Car will throw a P0451 code (Fuel pressure sensor) I believe.
The symptom in the video will only happen sometimes. Sometimes the car will start up and drive fine like nothing ever happened. Then sometimes when approaching a red light at idle, the car will stall and turn off. When the car dies it will make the same symptoms from the video shown above. The car could also make the symptoms shown from the video above as well from a regular start.
I never seemed to have an issue with starting the car from cold starts.
What would you guys suggest?
Things crossed off the list.
-Fuel cap
-Maf Sensor
-Fuel Pump
My mechanic has had my car for a few weeks now and still no luck. He's been checking for a possible bad ground wire. Has anyone had a symptom similar to this?
AndehLu is offline   Reply With Quote
Old 05-16-2019, 12:35 AM   #2
Brz_racer
Drives: Subaru BRZ
Does the car ever die at red lights and you aren't able to start it again? This would indicated an alternator failure. However if your getting a fuel pressure issue from the OBD I would run some seafoam through the gas tank and also check your fuel filter, could be partially clogged.
Brz_racer is offline   Reply With Quote
p0451
Car starts and dies immediately. P0171 (too lean) gkanga Issues | Warranty | Recalls / TSB 15 04-22-2018 12:16 AM
car dies when car is put in neutral aquaman Software Tuning 7 06-06-2017 09:21 PM
86 dies at stops Saviorself Issues | Warranty | Recalls / TSB 9 08-05-2016 04:00 PM
Car dies after 15-20 minutes? PolishFrs13 Issues | Warranty | Recalls / TSB 28 10-08-2015 04:28 PM
Electric dies when trying to start, disconnect/reconnect battery starts fine gregdobs Issues | Warranty | Recalls / TSB 10 05-12-2015 10:37 AM
