Old 05-10-2019, 02:41 PM   #1
snowdog
Drives: 2013 Scion FRS
EcuTek not reading engine codes?
So I have a CEL and thought I'd use my ecutek cable to see if it could tell me what code it was. Plugged in and software needed to be updated, So I updated. Detected vehicle and ran the Vehicle DTC Tool.
The following is what it showed me:
"Performing DTC Operations on...
Reading DTCs...
OBD Error during reading DTCs: No Response to ODB Request
End of DTC Operation
Any thoughts?
snowdog is offline   Reply With Quote
Old 05-10-2019, 05:35 PM   #2
steve99
Reading DTCs...
Any thoughts?
Thaat look like no connection to obd port.
Check obd cavle plugeed in all the way to obd port
Check you have ignition full on not jist accessory but engine stopped.
Also see if ecutek will do logging or a query ecu.
Looks more hardware issue to me
Old 05-10-2019, 05:44 PM   #3
tomm.brz
Drives: brz 2017 hksv2
but strange that it detected correctly the vehicle then
The Following User Says Thank You to tomm.brz For This Useful Post:
snowdog (05-10-2019)
Old 05-10-2019, 06:13 PM   #4
snowdog
Took it in to the auto parts store and tried their CEL reader.
P0390
P0391
Do you think this is tied to the tune or something else?
I would still like to know if others have had ECUtek DTC problems
Old 05-10-2019, 06:28 PM   #5
tomm.brz
if they read CEL than as steve said is something about your personal cable not doing goood connection or messed up drivers in your Windows, not tune related
Old 05-10-2019, 09:25 PM   #6
ls1ac
ls1ac's Avatar
The OBD connecters are well known to be flaky and give intermittent connections. In one case I was forced to buy a cable extender to complete a read and write.
Old 05-10-2019, 10:50 PM   #7
steve99
P0390
P0391
I have 3 ecutek kits 2 cables and blutooth, never had a problem reading dtc from any brz\86
snowdog (05-11-2019)
Lean engine codes p0171 zackegle Issues | Warranty | Recalls / TSB 23 03-14-2022 12:17 PM
ECUTek Cable not reading OBDII Anymore Cal3000 Software Tuning 16 08-29-2019 11:28 AM
Can Ecutek disable diagnostic codes? Kiske Software Tuning 3 05-16-2015 04:05 AM
Reading codes for TPMS B-R-Z Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 03-31-2015 01:04 PM
Check engine light on but no codes!?!? midnight23 Engine, Exhaust, Transmission 9 08-01-2014 11:20 AM
