Old 04-27-2017, 11:22 AM   #1
zackegle
Drives: 2013 brz limited
Lean engine codes p0171
Hey guys I've been having an issue with my car running lean I've taken it to the dealer they swapped the o2 sensors, checked my maf and checked injectors they said it's just my bottom injectors being clogged and they just put injector cleaner in it and said to run it for 1k miles to clear the problem.. I find that bullshit I've had this issue for a while and brought it to them countlessly so now I'm here asking for your guys help! I have a oft so I run realtime logs as I drive everything seems fine when driving on throttle but when I come to a stop my afr jumps to 15-17 my idles drop from fuel being spit into the engine (ST fueltrim goes up to 14) and that's when my lean code shows up ive also noticed if i mash the brake while at a stop it will jump my afr and raise ST fueltrim.. idk if that's normal but does that sound like i have a leak some where on the vacuum lines on the brake system? Where would i most likely find the leak? Please help!!
zackegle is offline   Reply With Quote
Old 04-27-2017, 11:50 AM   #2
Any mods other than oft?
Old 04-27-2017, 12:26 PM   #3
zackegle
Just a invidia catback and suspension bits, no engine mods
Old 04-27-2017, 12:29 PM   #4
100% sure you have no exhaust leaks?
Old 04-27-2017, 12:46 PM   #5
nunonuna
nunonuna's Avatar
According to his post in other thread, his car is stock other than oft stg1.
OP, This may not be the exact cause, but check PCV hose if that is loose somehow or leaking.
nunonuna is offline   Reply With Quote
Old 04-27-2017, 12:55 PM   #6
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
The garage basically did everything wrong. Instead of diagnosing the issue they started swapping parts. If they changed the O2 sensors, checked the MAF (if they even know how to) and (the worst of all) put in fuel injector cleaner , they have demonstarted that they do not know how to diagnose a problem and don't understand how to interpret a CEL.
If you go back to the same garage, they will find a reason that it's your fault. Go to a better garage.
Old 04-27-2017, 01:33 PM   #7
zackegle
I checked the exhaust when I installed my catback but there is an odd smell under the car near the engine when idling so there has to be a leak some where I'll have a look at the headers again this weekend and I'll check the pcv line but is pushing the brake suppose to raise afr? That just sounds odd to me
Old 04-27-2017, 01:37 PM   #8
nunonuna
nunonuna's Avatar
PCV = Positive crankcase ventilation.
I was referring to the hose that can be found behind the intake manifold runs down to PCV valve.
Old 04-27-2017, 01:37 PM   #9
zackegle
We only have one Subaru in town sadly but I think there diagnosing abilities are bad as well because the 5 times I've brought the car to them they had another excuse or "diagnosis" for the issue that's whybim just trying to do it on my own now
Old 04-27-2017, 01:40 PM   #10
zackegle
I'll try to find that hose and see I'm not 100% sure where it is though is it visible from the top
Old 04-27-2017, 01:48 PM   #11
nunonuna
nunonuna's Avatar
Yeah it is visible from top. Take off plastic engine cover & you will see better.
There are two hoses connected to intake manifold. PCV hose is the one on passenger side. I had air leak from there and had same code, but this may not be the case for you tho.
나의 SM-G935V 의 Tapatalk에서 보냄
Old 04-27-2017, 03:01 PM   #12
One of the troubleshooting checks for that code is exhaust leaks.
Old 04-27-2017, 08:36 PM   #13
zackegle
So I was checking my pcv valve line by disconnecting it and blowing smoke into it and I found a huge hole on this thing on the intake tubing would this be my issue and what does that container do? Can I block it off?
Old 04-27-2017, 08:37 PM   #14
zackegle
I think I may have found the leak but that line seems fine
Chech Engine Light On P219A P119E P0171 tonytduc Issues | Warranty | Recalls / TSB 4 09-21-2022 04:09 PM
Throwing P0171 and P1170 codes B-R-Z Software Tuning 39 01-27-2018 09:56 PM
too lean issue? p117B p0171 engine codes zackegle Issues | Warranty | Recalls / TSB 1 03-21-2017 08:03 PM
Crazy high LTFT, lean codes, e85... nickw14 Software Tuning 18 06-23-2015 08:55 PM
P0171 and P1171 codes help! dejxx Issues | Warranty | Recalls / TSB 3 03-24-2015 11:36 AM
