Old 05-10-2019, 06:42 AM   #1
j_ros94
Drives: 2017 Subaru BRZ
Engine Heat
I have a turbo BRZ and whenever I have the AC on the engine bay gets hot and starts to fog up my windshield from the inside. I i defrost it by using heat because cold air makes it fog even faster. Any ideas what it could be?
Sent from my SM-G960W using Tapatalk
j_ros94 is offline   Reply With Quote
Old 05-10-2019, 07:36 AM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
My guess is that, since you have a turbo system, the car isn't doing well with heat management. Maybe the intercooler is robbing the cooling air that the AC condenser needs. This would lead to heat soak in your refrigerant system .
The AC system does two things at once: it cools the incoming cabin air and dries it. Therefore, if the AC condenser isn't able to cool the refrigerant sufficiently, it would cause you to have cool, wet air hitting your windshield leading to fog.
EndlessAzure is offline   Reply With Quote
Old 05-10-2019, 07:47 AM   #3
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
id say you probably need a vented hood or put anti fog on your window. i know that when i have my ac on high and i floor it with just flex and headers the ac goes warm so i cant imagine the amount of heat you have
Breadman is offline   Reply With Quote
Old 05-10-2019, 07:51 AM   #4
j_ros94
Oh I see. I'm gonna see if I can ask the people who help me install to check the engine temps. Could a tune help with engine temps?
Old 05-10-2019, 09:58 AM   #5
A tune will not help. You have to get the hot air out and cooler air in. It isn't so much that your engine temperature is high but that the engine bay it self is. Are your headers wrapped?
Old 05-10-2019, 09:59 AM   #6
j_ros94
No. I probably should get heat wrap
Old 05-10-2019, 10:01 AM   #7
Has nothing to do with your header or flex. The AC in these cars use a clutch system that disengages the compressor at higher RPMs. Will happen on a bone stock car.
Old 05-10-2019, 10:02 AM   #8
It will help a pile.
Old 05-10-2019, 10:03 AM   #9
j_ros94
Thanks for that
Old 05-10-2019, 10:14 AM   #10
Thanks for that
The other option is to have them coated. Expensive but will make them last longer. The downside of wrapping is that you may reduce the life of the headers. Not a big issue unless you are running around at red line all the time but something you need to be aware of.
Old 05-10-2019, 10:16 AM   #11
j_ros94
I see. I'm gonna look around for shops that can coat it for me. Thanks!
Old 05-10-2019, 10:21 AM   #12
It is a start at any rate. As mentioned you may want to look at vented hoods as well. The more heat you reduce the better.
Old 05-10-2019, 10:22 AM   #13
j_ros94
I was planning about that vented hood for sure.
No Heat to Footwells? Xenith Issues | Warranty | Recalls / TSB 17 01-14-2016 10:14 PM
Engine Dress-Up, Heat Shielding & Motor Oil products @ OAKOS.com OAKOS Automotive Engine, Exhaust, Bolt-Ons 192 02-13-2015 01:38 PM
Heat Shields X Factor Engine, Exhaust, Transmission 4 09-05-2014 03:47 PM
Heat cycled. forwallblakmail Tracking / Autocross / HPDE / Drifting 23 06-25-2014 10:45 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
