Old 06-30-2014, 05:27 PM   #1
Nhil
Drives: 2013 Scion FRS
Rear end clicking noise after spring install
Tried a search and didn't find anything, wondering if anyone has some more ideas.
Started after I installed my RCE yellow springs, it sounds like a clicking sound from the strut tophats or endlinks but both are as tight as I can get them. Over bumps it's usually quiet, I hear it more when the suspension is loaded. IE, backing out of the driveway at an angle or loading one side of the car.
I didn't use an impact on the top bolt, springs are properly centered on the strut/tophat as far as I can tell.
Pretty sure this isn't the rear deck clicking noise since it started right after the springs and is audible on both sides.
Anyone have any ideas?
Nhil is offline   Reply With Quote
Old 06-30-2014, 06:08 PM   #2
Racecomp Engineering
Hard to tell from here, but please feel free to give us a call. It should be quiet.
- Andy
Old 07-16-2017, 09:44 PM   #3
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
Did you ever figure out what caused this noise? I have similar "click"/"tink"/"tight metal noise" from the rear. I've noticed this after I installed my Whiteline subframe inserts.
ApexEight is offline   Reply With Quote
DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise. Mikepage DIY (Do-It-Yourself) Guides 54 10-21-2020 02:34 PM
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 04:55 AM
Clicking / Ticking Rear Noise shellslinger Issues | Warranty | Recalls / TSB 19 07-20-2017 09:40 PM
Clicking noise from left rear control arm? pghfan19 Issues | Warranty | Recalls / TSB 7 07-29-2014 06:48 PM
Rear end clunk after H&R Super Sport Spring Install Taber Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-27-2013 08:40 PM
